Indogo dont a find an image , but its there.
- giorgiomartini
Hi , i am trying to do a render with indigo.
but it says it doesnt find the material on my wooden model.
the albedo on the material of my wooden model is set to a folder in my desktop.
in blender i have the wooden model uv unwrapped with the texture that is in th same folder in destop
and then i have also the same texture in the texture panel in the material .
so all 3 have the same texture, wich is in the same path.
what im i doing wrong.
why indigo wont find it ?
thanx!
thanx!
- indigo.jpg (268.13 KiB) Viewed 2676 times
Re: Indogo dont a find an image , but its there.
Does Indigo give an error message?
Or does the scene just render incorrectly?
- giorgiomartini
OnoSendai wrote:Does Indigo give an error message?
yes it gives me the error that it doesnt find the image.
Did you activate "texface" and "UV" in "map to"?
- giorgiomartini
yes , i did.
all paths are the same.
all materials have textface , they are unwrapped , set to map input to uv.
heres the packed blend file , if someone is so kind to check.
http://www.mediafire.com/?sharekey=0217 ... b9a8902bda
thanx!
thanx!
- giorgiomartini
this is the error , the path is in my mac .
it says something about , private, can that be the issue ? the thing is that the images are on my desktop.
Error: SceneLoaderExcep: Failed to load texture '/private/tmp/../Users/tweakingknobsgiorgiomartini/Desktop/Tweakingknobs_web_2009/Proyectos_videos_images_blends/Tweaking_2_big_Knobs/WoodFine0003_L.jpg': Error loading texture file '/private/tmp/../Users/tweakingknobsgiorgiomartini/Desktop/Tweakingknobs_web_2009/Proyectos_videos_images_blends/Tweaking_2_big_Knobs/WoodFine0003_L.jpg' - file not found
There is something wrong with the path ... double check!
take care
psor
take care
psor
"The sleeper must awaken"
sounds like an administration/permission denied...
what is the file name you want us to download?
