noise and dimension
3 posts • Page 1 of 1
lego
noise and dimension
Post by lego » Mon Nov 13, 2006 2:40 am
Maybe someone of you have already experimented this:
is it better to render an image at resolution x y, or at 2x 2y and then resize?
which solution gives less noise in the same time?
Lotuspec
Post by Lotuspec » Mon Nov 13, 2006 5:24 am
I think rendering at normal resolution shouldn't give more noise then at double resolution but the other way around is not so sure without knowing more about the implementation details. (depends on the sampling strategies used)
But either way I don't think you should bother as the difference is probably negligible anyway.
Kachu
Post by Kachu » Mon Nov 13, 2006 5:38 am
2x does give you the advantage of AA, but time gain is exponential so pick your poison.
Users browsing this forum: Semrush [Bot] and 85 guests
