Indigo basic tutorial + max9 scene
4 posts • Page 1 of 1
loran
Post by loran » Fri Nov 10, 2006 10:00 am
download indigo v06-test6-
http://www.indigorenderer.com/montecarl ... _test6.zip
unzip and put files to C:Indigo (*.exe at this level)
download max exporter -M2I_615beta2-
http://irrdev.com/ktuser/u3dreal/Export ... 5beta2.rar
copy "U3D-IndigoExport RC0.615\Exporter\scripts\" content
to "3ds Max 9\Scripts" folder
copy "\U3D-IndigoExport RC0.615\Exporter\scripts\startup" content
to "3ds Max 9\Scripts\Startup" folder
copy "U3D-IndigoExport RC0.615\Exporter\UI\Macroscripts" content
to "3ds Max 9\ui\macroscripts"
copy "U3D-IndigoExport RC0.615\Master" content
to "C:\Indigo"
install is done now!
start max
menu "Customize" -- "Customize User Interface"
select the Menus bar tab.
select "U3D Tools" from Category
you can drag and drop the Max2Indigo to a devlopped menu on the right. I personaly put it on top of Rendering section.
now you can launch your Indigo render window by going on Menu "Rendering" --"Max2Indigo"
you have 5 Indigo materials, emitter provide any objects illumination effects. you can use standart max lights. to use the Indigo PhysicalSky you have to put a direct target light in the scene first.
camera must but targeted. no sky light in the scene.
RenderWindow:
enable Tonemapping in the Tonemapping tab. If not your scene might be over exposed.
go to camera tab and hit render!
the max9 scene
http://laurent.renaud.free.fr/divers/In ... indigo.max
during render you can go for shopping or travel. few weeks later you will see your beautifull render is nearly done!! :lol:
atmmatt
Post by atmmatt » Fri Nov 10, 2006 10:33 am
Hi Loran, is this a new exporter?
"To be, or not to be" That is a question?
u3dreal
Post by u3dreal » Fri Nov 10, 2006 10:44 am
Thanks for the contribution loran...!!!!
Sorry but i'm already doing the coding so it is very good i get some help
with support and tutorials.... !!!
cheers
u3dreal ;)
filippo
speed test
Post by filippo » Mon Nov 13, 2006 2:04 am
If we used this file to do a speedtest?
render time:
resolution:
pc or render farm
