Tiny video tutorial (updated):
Tutorials/guides/tips on how to use Indigo and the Indigo exporters
9 posts • Page 1 of 1
dakiru
Post by dakiru » Wed Aug 26, 2009 5:57 am
What we need:
1. Any amount of frames, that we want see in the video.
2. Virtual Dub (I used 1.9.4 x64)
3. XViD - (I used 1.2.1)
So:
1. Prepare frames (same quality, same resolution)
2. Turn Virtual Dub on
Go to: File -> Open video file
Change: Files of type: Image sequence(*.png, *.bmp,*.tga...)
Choose first frame of your sequence
Click: Open
go to: Video -> Frame rate
Change:
Source rate adjustment:
Select: "Change frame rate to (fps)" option. Enter needed frame rate.
Click: OK
Click: Play (don't forget to rewind the video to the start after you played it)
Adjust the speed of you video with the help of "try and error" method :)
Click: RMB on the video pane (input)
Select: Select the aspect ratio based on your frames ratio.
Note:
NTSC = 720×480 and 30fps
PAL = 720×576 and 25fps
Click: Video -> Compression
Select preferred codec and adjust it's settings
Click: OK
Click: File -> Save as AVI -> Select where you want to save it
3. Check you video file.
Edit:
Thank you, guys, for your help!
Re: Tiny video tutorial (light layers):
Post by pixie » Wed Aug 26, 2009 12:11 pm
In step 2 I like adding fade between the layers so that one can get a smooth idea of the light being added in each step. Having the codecs installed the last step can be discarded since you can compress within VirtualDub.
But I think it's a much needed tutorial, I would just like it to have the pictures and the final video so that one could actually see it running.
Post by Borgleader » Wed Aug 26, 2009 12:14 pm
Also, specify that its either NTSC or PAL depending on region not just PAL, where I live we use NTSC
Post by pixie » Wed Aug 26, 2009 8:28 pm
Borgleader wrote:Also, specify that its either NTSC or PAL depending on region not just PAL, where I live we use NTSC
I think these settings have no effect unless you want to see the movie on a dvd player. From my understandment these settings were for tvs, not lcd connected to computers.
Post by suvakas » Wed Aug 26, 2009 9:09 pm
Cool...but I have one question - why are you using so many different programs? Can't you just open your png sequence in virtual dub and save as compressed xvid. Am I missing something?
@pixie
There is a difference in resolution and fps.
Post by pixie » Wed Aug 26, 2009 9:20 pm
suvakas wrote:Cool...but I have one question - why are you using so many different programs? Can't you just open your png sequence in virtual dub and save as compressed xvid. Am I missing something?
@pixie
I know that they are different, I was just saying unless for displaying on tv screens these modes aren't of much relevance for being displayed on computers.
Post by suvakas » Wed Aug 26, 2009 9:26 pm
Well.. you were writing, that PAL/NTSC "have no effect", but they have - PAL is larger and has a lower fps - no matter on what screen. :wink:
Post by Pibuz » Wed Aug 26, 2009 10:40 pm
@ dakiru
Thank you a lot! I gotta definitely start to play with this!
@ suv
If there is (and you know :wink: ) a simpler way to make a light animation (you say..virtual dub?) could you please post a small how-to? It's not that i don't appreciate dakiru's work, but - as he said - perhaps there could have been simpler methods.
dakiru
Post by dakiru » Thu Aug 27, 2009 12:20 am
No, that's I am missing! I didn't find this feature before only after you pointed this out. I will update this small tut with your info. And no Movie Maker needed :lol:
