hi there,
i'm sorry to start my posts with an error report... sigh
here is the messages and some detalis, hoping to be of some help...
modeller: blender3d v2.41
exporter: Indigo 0.6test5 (beta4) export script
message: The instrucion "0x004140c5" has refered to the memory "0x00000000". The memory could no be "read".
cheers,
jtassinari
memory could not be read
jtassinari
jtassinari
hi SmartDen,
i forgot to add the last details.
The export was fine and i create my 13mb xml.
So I went cmd and run indigo.exe after i modify the inifile.txt,
and modified inside it:
- PATH & FILENAME,
- Width and Height.
that's all.
right now I used exporter 0.4, and started a mach between the two XML files to fine where i got the "bug". The simple 0.4 missed some shades but it has worked.
cheers,
jTassinari
- PATH & FILENAME,
- Width and Height.
that's all.
cheers,
jTassinari
By the way...
if you start indigo from commando box indigo <scene>.xml you don't need to edit inifile. Because scene file is specified and all other settings was written by blender exporter in xml-file. You need to edit Ini only if you start indigo per double-click in WinExplorer. If scene exported from Blender you must at least specify the scene file
