Blendigo 2.0.10
Blendigo 2.0.10
http://www.indigorenderer.com/dist/plug ... taller.exe
Changelog:
* Exporter now checks 'Program Files' for Blender scripts dir, as well as 'Program Files (x86)' and the appdata dir, and if not found, allows manual script dir locating.
From smartden:
* fixed external materials
* render output path for windows
* motion blur with worldscale
* sun and sky layers
* motion blur with corrected rotation quaternion
* motion blur with "between" frames
Changelog:
From smartden:
Re: Blendigo 2.0.10
Checking for installed Python... No installed Python found.
Re: Blendigo 2.0.10
Oops.
Didn't notice it was on my secondary hard drive, which I just re-formatted.
Thanks, lol.
Edit:
No, I do have python installed on this drive..But blender isn't detecting it?
Thanks, lol.
Edit:
Re: Blendigo 2.0.10
Try setting the PYTHONPATH env variable; on my computer, it's set to
C:\Windows\system32\python26.zip;C:\Python26\DLLs;C:\Python26\lib;C:\\Python26\\lib\\plat-win;C:\Python26\lib\lib-tk;C:\Python26;C:\Python26\lib\site-packages
http://www.blender.org/forum/viewtopic.php?t=11938
looks like it may be useful.
Re: Blendigo 2.0.10
I originally had 3.1, I tried 2.6.2, then 2.6.1, and none of them worked.
All my other scripts work fine, but when I try to use 'Render with indigo', that error comes up in the console.
Re: Blendigo 2.0.10
Thx, I try it now
Re: Blendigo 2.0.10
Where can I change manualy Indigo path?
Re: Blendigo 2.0.10
you can't with this installer. why do you want to? indigo path will be written in registry by installaon. did you moved it after it?Jambert wrote:Where can I change manualy Indigo path?
Check normals, dude!
Re: Blendigo 2.0.10
I don't remember, maybe yes. I try a new indigo installSmartDen wrote:did you moved it after it?
Re: Blendigo 2.0.10
Thanks it works
But new problem, preview doesn't work
- Capture.PNG (81.48 KiB) Viewed 20365 times
Re: Blendigo 2.0.10
Guys, who use Linux, is there any trick that I don't know?
or it't just not available for Linux yet? And if it is so, will it be?
Re: Blendigo 2.0.10
Guess who uses Mac etc etc see Dakiru's post for the rest
Re: Blendigo 2.0.10
Hi, There is a problem with the download link of blendigo 2.0.10 : Each time I try to download, my web browser crashes (IE7).
I have tried to "Left click" on the link, as well as right click and "save target as".
So, I have notbeen able to download...
Re: Blendigo 2.0.10
Works just fine in Safari 4...
