I am trying to get blendigo to work on OSX with no success. The original install dumps all the scripts into .blender file in the user directly and overrides all the standard scripts, but in any case, I after I point it to the right Indigo folder its dosnt reander, goes back into 3d view with no error message or anything. I tried the latest blender version 2.0.9. By its self it installs into the blender.app if its in the Application folder, but it dosnt even start saying to check the Python console (which I dont know how to do in OSX), if I install 2.0.6 copy it to the right directory in the .app package, and overwire it with 2.0.9 it starts, but still no render and I cant pick the paths for the indigo render anymore. Please help! Ive spent money getting a license for Indigo, if I cant use it with blender in OSX that will be quite bad.
DrD
Please help cant get it to work on OSX at all
Re: Please help cant get it to work on OSX at all
Well I wish I could help you but I can't say I have experienced any trouble at all getting blender, indigo, or blendigo installed.
If it helps at all I would suggest you "uninstall" blender using AppZapper same for indigo. And then start fresh by downloading latest blender from blender.org, install it, download indigo 2.08 (latest mac version), install it then download blendigo 2.09 and install it.
So I suppose all I am saying is that I can confirm that the mac versions of all do work together and so I can only assume that something has gone wrong at some point on your machine.
Not much help I know, sorry, but it's the best I can do at this point.
Argh, finally got it to function,
The default 209 installer does not seem to unpack the Assets directory correctly, so I had to manually extract it from the installer and dump in into .blender
The other thing, the indigo renderer needs to be in the main application directory, and cant be part of a sub directory as it arrives usually arrives in.
drd
drd
