Hello everyone.
I'm new to using indigo, and I downloaded the SkIndigo program as well as Indigo. I also downloaded the Skindigo tutorial - getting started. However, I cant even complete the render step because I get this error message:
Error: SceneLoaderExcep: ModelLoadingStreamHandlerExcep: UV set with index 1 was exposed, but the UV set data was not provided. (In element 'mesh', around line 6, column 9)
I have searched the forums and found 2 posts with the same issue, however I do not understand why I am running into this since I am using a tutorial, which would be set up properly. I made sure that all the steps were done properly when i loaded the programs, and I also made sure both Indigo and SkIndigo were the 1.0.9 versions.
Please help me I just want to get started, it looks like a great program.
I cant even do sketchup tutorial render because of errors!
- Indigo_Error.JPG (17.5 KiB) Viewed 3893 times
Re: I cant even do sketchup tutorial render because of errors!
Hi and welcome to indigo.
Are you sure that you are not using a 2.0.X release of Indigo? I don't think you would be getting this error message if you were using Indigo 1.0.9. (Hope I'm not wrong...
Oh your right! Its the 2.0 version. Its still left on my laptop even though I thought I erased it before I loaded the older version. I will try to make sure its completely gone and see if it loads in the correct version. Thanks!
