Cindigo 2.0.6 - beta
Post by fused » Tue Jun 09, 2009 12:19 pm
for Indigo 2.0.6
(relatively compatible with Indigo 1.1.18)
10.06.09 0:10 (UTC): uploaded versions with fixed motion blur export - make sure to download them
17.06.09 11:25 (UTC): added mac version
download exporter:
cindigoR9.zip
Cindigo 2.0.6 R9 - PC
x86
(2.89 MiB) Downloaded 432 times
cindigoR10.zip
Cindigo 2.0.6 R10 - PC
x86 + x64
(3.26 MiB) Downloaded 484 times
cindigoR11.zip
Cindigo 2.0.6 R11 - PC
x86 + x64
(3.27 MiB) Downloaded 528 times
Cindigo 2.0.6.zip
Cindigo 2.0.6 R10 and higher - Mac
(3.6 MiB) Downloaded 516 times
Make sure you have the newest version of quicktime installed! Previews will not work with the 64 bit version bacause of the lack of 64 bit quicktime.
Good beginner tutorials can be found here (german and english, a bit outdated), a video tutorial for beginners here
The Cindigo Blog
changelog wrote:Cindigo 2.0.6:
* fixed motion blur bug
* added camera motion blur (note that only keyframe based animation can be evaluated for now)
* improved motion blur - can now be controled wit the "streght" parameter in the motion blur tag
* readded motion blur - controlled by the c4d motion blur tag (note that only keyframe based animation can be evaluated for now)
* fixed bug with only 1 material on object with selection
* batch file is back in windows versions....
* added camera tonemapping default response function
* Re-added export statistics in c4d console
* fixed issue of export settings not able to be saved under vista, win7 and OS 10.5 (if c4d was inside c:/Program Files or /Applications) (previews still missing) (R11 only fix)
* albedo tab is now hidden when "nk data" is enabled
* re added default background light when no settings present
* added supression of indigo instance conversion to mesh for export
* fixed mac export and run; cannot take any start parameters
* dumped batch scripts, using system() now
* more memory leak caused by light conversion fixed
* memory leaks eliminated
* indigo instance: fixed creation bug
* mac version fixes
* R11 fixes
* R9 fixes
* removed resolution and aspect ratio from camera tag
* fixed crash bug with indigo render settings video post
Please tell me if you find bugs or have specific requests. i will try to fix/implement as fast as possible.
WARNING: Its still a beta and some settings in the export window are not used or broken (animation export, seperate materials/settings, etc). there is also some stuff missing (indigo instances, etc.). But the stuff that works at the moment works very well :)
Re: Cindigo 2.0.6 - beta
Post by fused » Tue Jun 09, 2009 12:24 pm
you might also want to check out those testscenes demonstrating motion blur and other stuff.
testscenes.zip
Cindigo 2.0.6 testscenes, R10+
(747.98 KiB) Downloaded 444 times
Post by OnoSendai » Tue Jun 09, 2009 12:47 pm
Sounds great, thanks Fused!
Post by Zom-B » Tue Jun 09, 2009 8:21 pm
Finally Motion Blur.... thanks a lot Fused.... also for the other fixes and features!
iacx
Post by iacx » Tue Jun 09, 2009 8:22 pm
Cindigo for C4D 11!!!!!!! :D
Thanks Fused!
Post by fused » Tue Jun 09, 2009 9:31 pm
iacx wrote:Cindigo for C4D 11!!!!!!! :D
Thanks Fused!
Please let me know if you still encounter those problems you had with the versions before.
Phoenix
Post by Phoenix » Wed Jun 10, 2009 1:23 am
Thank you fused!
But what exactly does relatively compatible with Indigo 1.1.18 mean?
Post by PureSpider » Wed Jun 10, 2009 1:54 am
Background lighting, for example, has changed and won't work with 1.1.18 any longer
Post by fused » Wed Jun 10, 2009 1:58 am
Phoenix wrote:Thank you fused!
No problem. It means that you can render Cindigo 2.0.6 exported scenes with Indigo 1.1.18, as long you don't use 2.0 specific features (motion blur at the moment).
PureSpider wrote:Background lighting, for example, has changed and won't work with 1.1.18 any longer
No. Background lighting will work fine with 1.1.18. The reason you have problems with it is that you use 1.1.14 and background materials were introduced in 1.1.15.
Post by zeitmeister » Wed Jun 10, 2009 2:00 am
The "Indigo Render Einstellungen" object is being moved to the post effects inside the C4D render dialogue.
Light Normalization Tags aren't any more, these settings moved to the material object of your emittive material.
@fused: I've got a few problems with the General Light Type settings: emittive materials just render black. I'll finish a test scene for you; maybe you could check where the mistake is...
Post by PureSpider » Wed Jun 10, 2009 2:02 am
fused wrote:No. Background lighting will work fine with 1.1.18. The reason you have problems with it is that you use 1.1.14 and background materials were introduced in 1.1.15.
:oops: Shame on me
Post by zeitmeister » Wed Jun 10, 2009 2:18 am
Ah, got it:
Seems like RGB emission spectrum is not being regarded correctly, neither with emission scale nor without.
With blackbody everything is just fine... strange.
iacx
Post by iacx » Wed Jun 10, 2009 7:10 am
Thanks Fused!
everything ok!
I have a problem in the scene with infinite light or solar: the lighting is only diffused, as if it were applied only to an object sky c4d11 ... maybe something wrong?
A simple example with sunlight activated.
Post by fused » Wed Jun 10, 2009 7:48 am
you need to set the sun object in the indigo render settings in the post effects at the moment. just drag an object thats supposed to be used for the sun position in the link field.
iacx
Post by iacx » Wed Jun 10, 2009 9:48 am
Thanks, I had not looked in the post effects! :oops: :D
Users browsing this forum: No registered users and 61 guests
