Error: Scene Loader Excep:
11 posts • Page 1 of 1
ssd
Post by ssd » Fri Jun 05, 2009 8:54 am
Every time I go to do a render I get this error:
SceneLoaderExcep:
Model loading stream handler excep:
UV set with index I was exposed but the UV set data was not provided (in element 'mesh'; around line 6, column 9)
Can you please tell me how to fix this error so I can see the renders? Thanks!
UPDATE: I found another post stating to use same software version of Indigo and SKindigo. This seems to work.
ngethin
Re: Error: Scene Loader Excep:
Post by ngethin » Tue Jun 09, 2009 5:34 pm
I have exactly the same error, I only started getting it after I downloaded Indigo 2 as well. I really need some help on this if someone can sort me out I would really appreciate it!
My error:
"Error: SceneLoaderExcep: ModelLoadingStreamHandlerExcep: UV set with index 1 was exposed, but the UV set data was not provided. (In element 'mesh', around line 6, column 9)"
Thanks guys!
Post by Whaat » Wed Jun 10, 2009 4:39 pm
ngethin wrote:I have exactly the same error, I only started getting it after I downloaded Indigo 2 as well. I really need some help on this if someone can sort me out I would really appreciate it!
My error:
Thanks guys!
Check all of your Texture settings with the SkIndigo Texture Editor to see if you are using UV set 1. Maybe you changed it by accident. If so, change them all back to SU (SketchUp default)
ngethin
Post by ngethin » Wed Jun 10, 2009 9:18 pm
Hi, thanks for trying to help me out!
I checked all my textures and the dialogue box that is shown in the middle of my screenshot, the ‘UV Set’ is the same for all of them, they are all set to ‘D’ whatever that means. I also did a test and removed all of my textured and colours so they were all default and I still for the same error, something about the mesh . Is there anything else I should be doing or am I looking in the wrong place?
Thanks for your time!
-Nick
screenshot of my situation
Post by Whaat » Thu Jun 11, 2009 1:39 am
Maybe you accidently created a new UV set (set 1) by right clicking on the skindigo context menu and saving the UVs to set #1.
Are you using SkIndigo 1.0.9? I will have to look into this because it might be a bug in this version of SkIndigo. You might be able to fix it by using the right-click context menu - purge all uvsets. It is hard to explain what to do if you have never used multiple uv sets before. It might be easiest if you post the SKP file and I will fix it for you. If you don't want to post it on public forums, you can email it to me: subd at shaw dot ca
ngethin
Post by ngethin » Thu Jun 11, 2009 1:57 am
Hey,
I got round it in the end I just used the older version of indigo. And I found out how to get the IGS by using the Skindigo menu in sketchup (my bad :P) do you want me to still send you the file for the sake of bug fixes?
Thanks for your help ;)
-Nick
ngethin
Post by ngethin » Fri Jun 12, 2009 7:43 pm
Hey Whaat,
I send you an email with my sketchup model, just incase you were able to figure it out and give me a hand on this, just wondering if you got it?
-Nick
Post by Whaat » Sun Jun 14, 2009 2:32 pm
ngethin wrote:Hey Whaat,
-Nick
I got it. Thanks!
Woody989
Post by Woody989 » Mon Aug 03, 2009 1:06 am
i have the same problem with my renderer, would you be able to send the bug fix to bobjuniortheturtle@hotmail.com? thank you :wink:
Post by Whaat » Mon Aug 03, 2009 5:27 pm
Woody989 wrote:i have the same problem with my renderer, would you be able to send the bug fix to bobjuniortheturtle@hotmail.com? thank you :wink:
I was not able to determine the bug. However, it seemed to be solved using the latest versions of indigo and Skindigo. Download them from the 'Downloads' section of the Indigo website and let me know if that fixes your problem.
Regards,
Woody989
Post by Woody989 » Mon Aug 03, 2009 5:40 pm
Would i need to download both or just one?
