Using Indigo 2.0.5/6 x64, Win 7 x64, Blendigo 1.1.18
Export to Indigo using Blendigo 1.1.18 with the default.igs option unselected and get this error message
Indigo GUI loads and pops up that error message.
It seems a .igs file is created with an extra .igs in the filename added as in WaterJug_Desert.igs.igs
Indigo pops up that error message and stops.
If I then cancel that message and use 'Open Scene' I can load this same file, for example WaterJug_Desert.igs.igs, it will load and render fine.
Exporting from Blendigo using the default.igs works fine with no errors
Error using Blendigo 1.1.18 and Indigo 2.0.5/6
- Doug Armand
Doug
Doug Armand
Doug Armand
Re: Error using Blendigo 1.1.18 and Indigo 2.0.5/6
Win 7!?Doug Armand wrote:Using Indigo 2.0.5/6 x64, Win 7 x64, Blendigo 1.1.18
sorry i can't say why it happens. it can be a win7 issue. i have no problems under winxp
Check normals, dude!
- Doug Armand
Any chance your working on an update of Blendigo?.....wouldn't mind playing with motion blur for one
Doug
Doug Armand
Doug Armand
Maybe the path to the scene file is incorrect. Hard to test that hypothesis, though.
