ok, ive bugged Smartden about this problem and he even fixed a file for me (it worked perfect) and i thought i had it sorted.....
it seems i dont, so i thought instead of bugging the poor guy again id ask around.
Im trying to render a simple gold ring with a gem in it and the gem keeps coming out black...
here are the screenshots:
help with a semi transparent gem
- here are the settings, i think i copied them correctly from the file Smartden fixed for me - but its not working now
- blendigo gem.jpg (88.84 KiB) Viewed 11824 times
- heres the render - could it be lighting? the normals are facing out, i checked
- im1240558871.png (1.1 MiB) Viewed 11826 times
Re: help with a semi transparent gem
I hope, smoothing is turned off?
And yes, turn off SSS... -except the gem shouldn't be clear...
Leave reinhard tonemapping alone, since the gem is the only light absorbing material in the sky (!) it has to be dark with reinhard tonemapping.
Also put the ring on some surface and use emitting ones for lighting.
well, actually...
don't forget the gold^^ it also absorps. If it didn't, it'd be a perfectly grey-white reflector (a perfect mirror) rather than a golden one...
Users browsing this forum: No registered users and 118 guests
