Stones and Water.
12 posts • Page 1 of 1
kikeonline
Stones and Water.
Post by kikeonline » Thu Mar 26, 2009 6:54 am
Sup Guys!!!
I need Indigo's masters help.
How can I make those Stone more bumpy without displacement? They look very flat to me (on the rendered image) :(
Post by Borgleader » Thu Mar 26, 2009 10:11 am
Have you tried increasing the "b" value?
Post by CTZn » Thu Mar 26, 2009 11:53 am
Yes, did you evaluate the bump without a textured albedo first ?
What's the real limitation for not using displacement in this scene ?
SmartDen
Post by SmartDen » Thu Mar 26, 2009 8:57 pm
set the bump gamma value to 2.2
Check normals, dude!
Jambert
Post by Jambert » Fri Mar 27, 2009 5:50 am
water material is great :D
Psychotron80
Post by Psychotron80 » Fri Mar 27, 2009 9:41 am
Jambert wrote:water material is great :D
yep! can you post material settings, please?
Stur
Post by Stur » Fri Mar 27, 2009 9:54 am
May I ask why you don't want to use displacement ?
Bumpmaps always look flat when not seen from straight angles.
Post by Borgleader » Fri Mar 27, 2009 10:07 am
Stur wrote:May I ask why you don't want to use displacement ?
Indeed because bump mapping is just applying a a shadow map on top of the mesh to simulate the shadows. so the less perpendicular youre viewing angle is from the mesh surface, the "faker" it looks.
Post by CTZn » Fri Mar 27, 2009 11:04 am
The first part of your sentence is incorrect Borgleader, unlike the second :) Differences in shading with bump occurs because it is perturbing the normal to the surface, effectively changing it's local orientation to the renderer and thus the outgoing direction of light after it interacted with the material, it's not just perturbing albedo (not at all in fact).
What's the height of the walls above the water surface Kike ? 1 seems a strong value for bump but am not a blender user, am I missing something ?
kikeonline
Post by kikeonline » Sun Mar 29, 2009 6:33 pm
Thanks a lot for the suggestion, I will try them all.
I'm still learning displacement on blender and indigo.
see you guys later
8)
sandsturm3d
Post by sandsturm3d » Mon Mar 30, 2009 8:55 am
I hope some self promotion is allowed: did you consult the wiki?
http://www.indigorenderer.com/joomla/co ... placement/
Best regards,
Martin
Post by Borgleader » Mon Mar 30, 2009 9:27 am
sandsturm3d wrote:I hope some self promotion is allowed: did you consult the wiki?
Best regards,
Martin
I think it would be pretty illogical to bust you for promoting another part of the indigo website :lol:
Users browsing this forum: Yandex [Bot] and 13 guests
