... can everyone tell me the right way, how i give the materials to the objects? in c4d i import a indigo-material, give it to the object, but Indigo don´t render the material..
Thank You!!!
Indigo not render Materials, i have given the Objects...
fused on cgnetwork.de wrote:welche cindigo version benutzt du? 1.1.18 stable rc2?
eigentlich brauchst du das importierte material nur dem objekt zuweisen. es gibt allerdings ein paar materialien die parameter verwenden die (noch nicht) von cindigo unterstützt werden (z.b. das checkerboard material, ein paar mit SSS...). diese werden dann nur teilweise importiert (checkerboard bleibt dann einfach nur weiß).
Blue Recluse
Re: Indigo not render Materials, i have given the Objects...
I have the same problem. I can create Indigo textures in C4D but any texture I import renders appears either grey diffuse or clear specular in the C4D material editor, but renders completely black with a phong appearance. I can render the Indigo material editor, but they don't import into C4D or export out. Please help!
- zeitmeister
Scene-file please. But please check the scene scale first and try "mm".
Do you drag the created Indigo Material(!) onto your object in the viewport or objects list?Blue Recluse wrote:I have the same problem. I can create Indigo textures in C4D but any texture I import renders appears either grey diffuse or clear specular in the C4D material editor, but renders completely black with a phong appearance. I can render the Indigo material editor, but they don't import into C4D or export out. Please help!
Lenovo IdeaPad Y510: Core2Duo 2.1GHz, 2GB RAM, GeForce 8600M GT, WinXP Pro SP3, Cinema 4D 11.5/Blender 2.49 and Indigo 2.2.12 with Cindigo 2.2.11/Blendigo 32-bit
Users browsing this forum: No registered users and 76 guests
