Hi guys
I think I need a little help here.
I'm making a test for instancing objects, but I keep getting the same error (Error: IndigoDriverExcep: Memory allocation failure.)
I've never seen this error on either my desktop or laptop. I thought it might be a problem, that I had dummies inside dummies, but that wasn't it.
I woul really appreciate some help, and I posted the skippy and here's the indigo log:
WARNING: Ignoring degenerate triangle. (triangle area: 0.00000E+000)
Merging vertices for mesh 'Color_H15'...
Initial num vertices: 28
New num vertices: 28
Done.
Merging vertices for mesh 'Default'...
Initial num vertices: 148
New num vertices: 148
Done.
Merging vertices for mesh 'floor'...
Initial num vertices: 2049472
New num vertices: 2049370
Done.
Merging vertices for mesh 'floor_dummy'...
Initial num vertices: 24
New num vertices: 24
Done.
Building Mesh 'Color_H15'...
28 vertices (672 B)
14 triangles (392 B)
Loading kd-tree from cache...
intersect_tris mem usage: 672 B
calcing root AABB.
AABB: (36.474098, 9.228800, 0.000000), (42.074100, 12.828800, 47.000000)
max tree depth: 62
total nodes used: 27 (216 B)
total leafgeom size: 18 (72 B)
Total tree mem usage: 960 B
Done Building Mesh 'Color_H15'. (Time taken: 0.00953 s)
Building Mesh 'Default'...
148 vertices (3.469 KB)
86 triangles (2.352 KB)
intersect_tris mem usage: 4.031 KB
calcing root AABB.
AABB: (-90.576698, -89.145897, -0.082300), (109.423302, 110.854103, 47.000000)
max tree depth: 62
total nodes used: 316 (2.469 KB)
total leafgeom size: 248 (992 B)
Total tree mem usage: 7.469 KB
Done Building Mesh 'Default'. (Time taken: 0.00977 s)
Building Mesh 'floor'...
2049370 vertices (46.906 MB)
1115988 triangles (29.800 MB)
BVH::build()
Calcing root AABB.
Done.
Root AABB min: (0.022100,0.022100,-0.060500)
Root AABB max: (37.108700,22.892300,3.002700)
Sorting...
Done (0.41104 s).
Allocating intersect triangles...
Done. Intersect_tris mem usage: 38.314 MB
Build Stats:
Total nodes used: 639396 (39.026 MB)
Total nodes capacity: 941613 (57.471 MB)
Total tri indices used: 1523572 (5.812 MB)
Num sub threshold leaves: 627452
Num max depth leaves: 11944
Num cheaper no-split leaves: 0
Mean tris per leaf: 1.745378
Max tris per leaf: 63
Mean leaf depth: 29.527391
Max leaf depth: 63
Finished building tree.
Done Building Mesh 'floor'. (Time taken: 3.22141 s)
Building Mesh 'floor_dummy'...
24 vertices (576 B)
12 triangles (336 B)
intersect_tris mem usage: 576 B
calcing root AABB.
AABB: (0.000000, 0.000000, 0.000000), (36.948399, 22.857700, 3.002700)
max tree depth: 62
total nodes used: 14 (112 B)
total leafgeom size: 12 (48 B)
Total tree mem usage: 736 B
Done Building Mesh 'floor_dummy'. (Time taken: 0.01061 s)
Light luminous flux (geometry name=EnvSphereGeometry): 2.201E+012 lm
Building Object Tree...
34 objects.
calcing root AABB.
AABB: (-1626.993896, -1626.993896, -1626.993896), (1626.993896, 1626.993896, 1626.993896)
max tree depth: 12
reserving N nodes: 34(272 B)
total nodes used: 55 (440 B)
total leafgeom size: 134 (536 B)
Num buffer layers: 1
Master buffer size: 50.028 MB
Settings:
Frame upload period: 40.00000 s
Image save period: 120.00000 s
Splat filter: mn_cubic, blur=0.600000, ring=0.200000
Downsize filter: mn_cubic, blur=0.60000, ring=0.20000
Render region: false
Supersample factor: 2
Metropolis: true
Bidirectional: true
Hybrid: false
Ray origin nudge distance: 0.00010 m
Aperture diffraction: false
Post-process diffraction: true
Finished initialisation
Starting threads... (num threads: 2)
Starting render thread. (RNG seed=1)
Starting render thread. (RNG seed=2)
Doing initial warmup.Doing initial warmup..........
Done initial warmup.
Render thread terminating.
Stopped.
memory allocation problem in instanced scene
- danbyg.zip
- (76.44 KiB) Downloaded 246 times
hi pibuz
No plugins used. I just copied and rotated. I did scale a few of the dummies, but that shouldn't be a problem should it?
You haven´t tried rendering the scene on your rig, by any chance? I'm just wondering if it's somekind of configuration on my system. I'm using a small application for freeing memory, but I've tried with it both on and off.
Hi guys... what bugs me from the log 2kemon is that the render threads are terminating wich is unusual for memory allocation errors if I am correct (?). I think I've never seen Indigo stopping the render threads friendly before throwing an error (? again).
The frame buffer is allocated, no rendering limit was announced as reached in order to stop the render... I'll let you investigate on this one, I have no clues and it looks tricky... Hopefully the problem will stop after you change something in your scene (I can't load it against an older SK version but would not be able to use it really anyway) !?
It could be that the memory freeing application would not be safe with Indigo (well I'm supposing), did you try to reboot your system with the tool deactivated at startup before rendering (no auto-launch) ?
Good luck !
Good luck !
