Cindigo 1.1.18 - stable RC2
Post by fused » Sat Mar 14, 2009 7:21 am
for Indigo 1.1.18
download exporter:
Pc Version
Mac Version - soon
The PC version contains plugins for R10(32 and 64 bit) and R9(32 bit). R9 users will have to rename the "cindigo.cdl_R9" to "cindigo.cdl".
Make sure you have the newest version of quicktime installed! Previews will not work with the 64 bit version bacause of the lack of 64 bit quicktime.
Good beginner tutorials can be found here (german and english, a bit outdated)
The Cindigo Blog
changelog wrote:Cindigo 1.1.18 (stable RC2):
* fixed crf path bug (fused)
* disabled drawing the sphere of the render settings object (fused)
* fixed crash when trying to free unused normal array (fused)
* fixed unfindable instance reference crash (fused)
* removed Obase from material helper and material group object. experiamental, lets see if that causes problems (fused)
* fixed igm export and previews (fused)
* low priority bug fixed (fused)
* changes to the material helper: (fused)
- organized into tabs
- removed redundancies (diffuse color, exponent, etc)
- broke backwards compatibility a bit
Do you like Cindigo?
If you think its valueable software, please feel free to donate.
Please split the donation in two and donate the other half to Indigo.
Cindigo 1.1.18 RC2.zip
Cindigo 1.1.18 RC2
(3.45 MiB) Downloaded 613 times
Camox
Post by Camox » Sat Mar 14, 2009 7:42 am
Thanks fused for the fast release. :D
Camox
Post by Camox » Sat Mar 14, 2009 7:57 am
All testscene works fine, no bugs under r9.6! :D Great Work...
iacx
Post by iacx » Sat Mar 14, 2009 8:09 am
Fused thanks for RC2!
Using the blend of material I have always this error resulting crash.
I do not know if it is a problem C4D11 or a general problem.
I attach the image.
Crash_C4D11.zip
(59.06 KiB) Downloaded 353 times
Post by fused » Sat Mar 14, 2009 8:33 am
weird. pure virtual funtion call... its calling a funtion that should have been overridden by me. the compiler normally puts out an error if something like this happens, so i guess its an R11 problem...
i will try it myself with the R11 demo.
Post by fused » Sat Mar 14, 2009 8:34 am
oh, btw: the "external igm" material type isnt working yet...
Post by pixie » Sat Mar 14, 2009 10:20 am
Amazing job on the materials... :)
c 4
Post by c 4 » Sat Mar 14, 2009 11:00 am
Looking good so far, thanks fused.
iacx
Post by iacx » Sat Mar 14, 2009 9:08 pm
Here is the file Fused, the problem is clicking on the convert materials.
The strange thing is that the problem does not always!
Crash_C4D11.zip
(407.65 KiB) Downloaded 355 times
Post by fused » Sat Mar 14, 2009 10:53 pm
ill have a look at how much work a r11 would be (there were quite a lot changes).
edit: i tested the scene and for me it does not crash. im using R11.010.
edit: also tested the R9 version with R11 - no problems
iacx
Post by iacx » Sat Mar 14, 2009 11:38 pm
I do not know what to say, but in my case: Vista 64, c4d 32-bit and 64 bit 11.021), adding a material blend the work becomes very unstable and can go to crash.
Thanks Fused. :)
Post by pixie » Sun Mar 15, 2009 6:45 am
What about extending the rendering object so that one export from it too?
Rafaello
Post by Rafaello » Sun Mar 15, 2009 8:54 am
Thanks fused, great job with the exporter.
Btw I have R11.021 and the iacx scene works fine with the 32 and 64 bit versions running XP 64, perhaps is a vista problem.
Rafaello
Post by Rafaello » Tue Mar 17, 2009 4:02 am
The exporter works great, here is an example with instances with the 64 bit version.
Just an instancing test
Post by fused » Tue Mar 17, 2009 4:32 am
:D nice carpet!
