another UVtex pb when switching to 1.17 ? Solved
1 post • Page 1 of 1
delic
Post by delic » Thu Mar 05, 2009 4:59 am
Error: IndigoDriverExcep: SceneLoaderExcep: ObjectExcep: No such uv set 'UVtex' (In element 'model', around line 1207, column 5)
I try to convert a 1.09 scene to 1.17, and, yes I corrected all objects in my scene to UVtex.
I edited the mesh.xml file, looked around that line, to see what object cause this pb.
But the object has no textures on it ! so no uv or UVtex !
Even when "hiding" the object on an another layer that is not rendered, always the same Error message !
I browsed every indigo materials on the scene, no one contains a material with a texture that is not set to UVtex, like in the blender edit tab, uv type.
So I also looked if a blender material would have some material with UV mapping not set in "map to" panel .
Now I'm lost, does anybody have an idea what could be wrong in the scene, knowing it works perfectly on 1.09 ?
I saw the message about about a hundred times, for several hours, I'm becoming nervous ...
thx
Edit :
Solved ! UVTex/UVtex ... :oops:
