Indigo 0.6 test 1
Indigo 0.6 test 1
Post by OnoSendai » Thu Jul 20, 2006 1:33 am
hey all, new release time.
I wanted to get the Multithreaded stuff out the door... because... well, it's just so cool (IMHO :))
http://www.indigorenderer.com/montecarl ... _test1.zip
This is a stand-alone release, it includes all necessary files.
As usual, I may have broken some stuff, so keep an eye out :)
So Indigo is now fully multithreaded.. you can run an arbitrary number of threads per process.
Scene file changes:
Just one minor one, but it will break most scenes:
The background element now should only have 1 child, a spectrum element.
So e.g.
	<background>
		<radiance>1 1 1</radiance>
	</background>
should be changed to
     <background>
		<spectrum>
			<rgb>
				<rgb>1 1 1</rgb>
			</rgb>
		</spectrum>
	</background>
Also you can now have only one of background, skylight, or env_map.
If you want a black background, don't include a background element.
changelog:
* speedup with phong pow()s
* added bump mapping for specular mat
* Added multithreading
* Added -t switch to specify number of threads.
* nice error message on out of mem while building kdtree
* using doubles for pdf and radiance stuff
* added colour correction
* background element now takes a single spectrum child element
* can now have only one of background, skylight, or env_map
* made window size equal to render size
* changed default sky gain to 0.002
* changed bidir RR live prob
* decreased num warmup mutations by half
Re: Indigo 0.6 test 1
Post by Zom-B » Thu Jul 20, 2006 2:16 am
Ono-Sendai wrote:hey all, new release time.
This is so cool!!!!!!! :D
Thanks a lot for your hard work dude!
*now testing
yponomos
Post by yponomos » Thu Jul 20, 2006 5:30 am
great work!
tungee
Post by tungee » Thu Jul 20, 2006 8:10 am
thanx ono!
it was so silent the two last weeks!
psor
Post by psor » Thu Jul 20, 2006 9:28 am
Thanx a lot for this fine update! ;o))
take care
psor
Benchmarks...
Post by Zom-B » Thu Jul 20, 2006 12:35 pm
I did some quick & dirty benchmarks to test multithreting in 0.6 test 1:
I own a AMD X2 3.800+
1 Core 100%
2 Cores - 1 thread ~116%
2 Cores - 2 thread ~210%
2 Cores - 3 thread ~215%
Indigo seems to use my second Core also even if only 1 thread is defined.
Always when the log File gets Updated the second Core uses 10 to 15%.
I also recogniced, that using 3 threads raises Indigos Performance on my machine even more :shock:
Can somebody confirm my conclusions?
Post by OnoSendai » Thu Jul 20, 2006 2:12 pm
Well, when you set it to one thread, that means one thread that runs the MLT process, and another thread that does the tonemapping, gamma correction and display of the image buffer, which does take significant computation.
So it's really two threads.
Post by OnoSendai » Thu Jul 20, 2006 6:31 pm
Yeah.. i hacked a ~1.1 multiplier on the green component so that white actually maps to white under the sRGB etc.. transform.
yponomos
Post by yponomos » Thu Jul 20, 2006 8:09 pm
ono, can i ask something? can you send these kind of announcements
also by e-mail to the forum members? thus, we'll know immediately
when a new version is posted...
Post by OnoSendai » Thu Jul 20, 2006 11:52 pm
yponomos wrote:ono, can i ask something? can you send these kind of announcements
Heh.. I think that would annoy too many people... especially if i get up to v0.6test7 :)
Xman
Post by Xman » Fri Jul 21, 2006 2:16 am
thank Nick,
:D Very great work
u3dreal
Post by u3dreal » Fri Jul 21, 2006 3:07 am
Excellent as always..
I'm on the exporter.
Will colorcorrection work like before in the xml .. ?
Did the blend stuff go in there as well ?
So maybe i could do a blend mat for M2I..?
cheers
u3dreal ;)
Phoenix
Post by Phoenix » Fri Jul 21, 2006 4:52 am
Hey, great!
Thx for the new version Nick! 8)
And except for multithreading and all the other new feartures also for:
But:
Is it really correct, that the <rgb>, </rgb> stuff in <background> have to be defined twice?
<background>
<spectrum>
<rgb>
<rgb>1 1 1</rgb>
</rgb>
</spectrum>
</background>
Kind regards,
Tom
jurasek
Post by jurasek » Sat Jul 22, 2006 6:20 am
Dosen't work with Wine under Linux? Black screen all the time and there is no change in the .png file while rendering:(
greetz,
jurasek
mzungu
Post by mzungu » Tue Jul 25, 2006 10:23 am
Not able to get <env_map> to work with this release.
I've tried:
  • exr's for both spherical & latlong (converted with hdr2env)
  • & same for .float/.raw (converted from hdr with hdrshop)
  • using the common kitchen_probe.hdr as well as others (for latlongs)...
consistently gives me this error dialog:
I hope its just something I'm doing wrong...
-mzungu
"The fear of the Lord is the beginning of wisdom" - Solomon
