Indigo SDK 18
Discussion for users of the Indigo Renderer SDK.
Indigo SDK 18
Post by OnoSendai » Mon Feb 23, 2009 3:36 pm
Yes, I skipped a few revision numbers.
In-memory mesh definition is back.
http://indigorenderer.com/dist/IndigoSDK_18.zip
Post by fused » Mon Feb 23, 2009 6:10 pm
does in-memory mesh definition work with network rendering?
Post by OnoSendai » Mon Feb 23, 2009 9:09 pm
Hmm, no, it won't work currently.
Actually network rendering will be broken in this release, will fix soon.
Post by suvakas » Mon Feb 23, 2009 9:27 pm
Great news, awesome !
So it will now work as before the 15 release? (without any intermediate igs file on the disk ?)
Post by OnoSendai » Mon Feb 23, 2009 9:42 pm
No, it still uses an intermediate file for the non-mesh XML currently.
Post by suvakas » Mon Feb 23, 2009 9:46 pm
Gtocha.
But it will not stay like that in the future?
Post by OnoSendai » Mon Feb 23, 2009 10:27 pm
Suv: not sure, I may remove it in future.
I don't think it matters too much either way, the performance hit of writing to disk should not be significant, as long as meshes are passed in RAM.
For network rendering the scene has to be saved to disk anyway.
Post by fused » Tue Feb 24, 2009 5:13 am
cant get the in mem mesh definiton to work.
in the driver.cpp its done after executeCommand(), do i have to do it like this?
if yes: when is the scene xml read? on buildScene()? its rather unpractical if i have to go through the scene again to export the meshes...
Post by fused » Tue Feb 24, 2009 5:34 am
fused wrote:if yes: when is the scene xml read? on buildScene()? its rather unpractical if i have to go through the scene again to export the meshes...
i just checked it, it works perfectly when i call executeCommand() before i export the scene!
rgigante
Post by rgigante » Tue Feb 24, 2009 8:10 pm
hmmm... how can u call executeCommand before exporting the scene with an empty .igs file?
Do i miss something?
Can't you simply store in a vector a pointer to your object and then process the meshes after the complete scene processing?
Thanks, Riccardo
Post by fused » Tue Feb 24, 2009 8:35 pm
rgigante wrote:hmmm... how can u call executeCommand before exporting the scene with an empty .igs file?
Thanks, Riccardo
i wouldnt even have to store a pointer, because c4d offers me quite a nice structure i can use, but it means iterating throug all objects again and im already doing that quite often to collect info about instances and such.
also im using material overrides a lot (im exporting each used material of a mesh before the <model> exponent, because parameters, especially shader parameters, like the matrix of the c4d mat, which of course applies to shaders, are likely to change for each object) and to find all used materials on an object im just returning a list of material names from the mesh export.
id have to find the materials twice (once for material export and once for mesh export). ok, i doubt that this is too speed critical, but for a lot of objects it adds some overhead.
its just faster, easier to maintain and straightforward to do it like this, at least for my needs :)
indeed, the scene file is read after calling buildScene().
rgigante
Post by rgigante » Tue Feb 24, 2009 9:21 pm
Does it seems to me or the in the latest SDK the stopping the renderer takes longer compared to the previous releases?
R.
Post by fused » Tue Feb 24, 2009 9:35 pm
yeah, think so, too.
rgigante
Post by rgigante » Fri Feb 27, 2009 9:51 am
Bug found REV18:
if SuperSampleFactor is equal to 1 the LDR framebuffer is not computed. All the rendering process continues normally, but when it's time to call "copyBuffer" is doesn't feed the buffer with any value different than 0,0,0 (this is confirmed by the fact that also the watermark is not displayed)
Riccardo.
Post by fused » Sat Feb 28, 2009 5:37 am
i cannot confirm that. everything works fine here.
attached a scene exported with my plugin. renders good.
but:
fused wrote:also, the buffer returned by indigo is always 4 pixels higher/wider than the size you set (eg 320x240 / 324x244).
thats only with ssf = 1, maybe thats ur problem? since sdk 15.
meh, cant attatch a file....
