Exporting Problem
scott_s_06
Exporting Problem
When I try and run the blendigo script I get the following problem as seen in the picture. I used the installer to get blendigo.
Vista 32bit
Python 2.5.4
Blender 2.48a
Indigo 1.0.9
How do I fix this?
I tried searching for tutorials on how to use blendigo, but I kept getting links to 404 not found pages.
Vista 32bit
Python 2.5.4
Blender 2.48a
Indigo 1.0.9
How do I fix this?
- blednigo_problem.jpg (191.7 KiB) Viewed 16058 times
- Van Anders
scott_s_06
- Borgleader
yes thats exactly it. "IndigoWrapper.conf" is the file containing that information.scott_s_06 wrote:Not sure what that is, is that when you install blendigo and you have to tell it where blender is installed and where indigo is installed?
It should be mentionned though that anyone using the .exe provided by Smartden doesnt have to touch this file because its created/edited automatically by the exe itself.
From a non-blender user point of view, it could be that either indigoWrapper.conf is missing (probably not) or not set as required; 'datadir' seems to contain no path at all (string size = 0).
As suggested check the file again, maybe report its content here ? I don't know how it is read, maybe it can't assume an empty line as a beginning ?
- Van Anders
scott_s_06
nightshaade
Re: Exporting Problem
Sorry to bump thread. Have exact problem. Please more detailed explanation of indigowrapper.conf, can find this nowhere.
- Borgleader
It should be where Van Anders said it would be (look a few posts up) if its not there, then it hasnt been created. Are you using the blendigo installer or the zip file? Because the installer should technically create the file AND configure it for you.nightshaade wrote:Sorry to bump thread. Have exact problem. Please more detailed explanation of indigowrapper.conf, can find this nowhere.
nightshaade
Cannot find "Bpydata", Find "bpymenus". Installer used.
- Borgleader
Well it pretty much has to be there or else you have none of the blender default scripts...nightshaade wrote:Cannot find "Bpydata", Find "bpymenus". Installer used.
nightshaade
Blender 2.48 installed, Python 2.5.4 installed. Mayhaps security progs interfering?
- Borgleader
Nah, a security application wouldnt hide random folders like those...
nightshaade
Yes. They are not there.
