Violet Update
- The Unknown
Violet Update
Here is a little update of Violet with IGI-4 support, compatible with Indigo 1.1.17 files.
+ Support for IGI-4 (first layer only)
+ Checkbox to override SuperSampleFactor to 1
- violet4.zip
- Win32
- (599.38 KiB) Downloaded 1297 times
- violet4-src.zip
- Source
- (825.92 KiB) Downloaded 1058 times
- The Unknown
- The Unknown
Violet is running normal (slow) for me.
Glare is not visible at the begining (in my scenes), I have to change Weight/Radius/Tone-Mapping so see some difference.
Dev-Info:
I compiled it with VS Express and in Express there is no 64-bit available (i think).
And i had to disable OpenMP to compile without error.
Dev-Info:
- The Unknown
- The Unknown
heres the x86er built against wxWidgets 2.8.10.
building wx takes a while on an atom,
still having a problem building a x64 version, always getting LNK1112... investigating.
edit: wx x64 seems to build fine now (no idea why it didnt work before...)
edit2: here we go, violet x64
- Violet_x64.zip
- Violet 64-Bit
- (775.96 KiB) Downloaded 1032 times
- Violet_x86.zip
- Violet 32-Bit
- (606.91 KiB) Downloaded 970 times
More troubles now, the x86 doesn't run on my xp 32 rig.
Winrar says it's impossible to run the application and when it's copied to the HD on a random place it says (I'm translating from the french message):
"this application could not start because the configuration of the application is incorrect. Installing the application again could resolve the issue."
