max resolution
carbon
max resolution
Post by carbon » Fri Dec 12, 2008 6:00 am
Hi, I am trying to determine the biggest possible render resolution, i am testing it on material preview scene and both 1.1.14 and 1.1.15 keeps crashing on any resolution higher than ~2000, i can't believe that this resolution is final.. i got this:
inished initialisation
Starting threads... (num threads: 2)
Starting render thread. (RNG seed=1)
Starting render thread. (RNG seed=2)
err:ntdll:RtlpWaitForCriticalSection section 0x3fd0e08 "?" wait timed out in thread 001a, blocked by 0019, retrying (60 sec)
wine: Unhandled exception 0x40000015 at address 0x7857bb47 (thread 0019), starting debugger...
err:ntdll:RtlpWaitForCriticalSection section 0x3fd0e08 "?" wait timed out in thread 001b, blocked by 0019, retrying (60 sec)
Process of pid=0008 has terminated
Oneiros:indigo_v1.1.15 carbon$ No process loaded, cannot execute 'echo Modules:'
Cannot get info on module while no process is loaded
No process loaded, cannot execute 'echo Threads:'
process  tid      prio (all id:s are in hex)
0000000c
	00000012    0
	0000000e    0
	0000000d    0
0000000f
	00000016    0
	00000015    0
	00000011    0
	00000010    0
00000017
	00000018    0
You must be attached to a process to run this command.
No process loaded, cannot execute 'detach'
some specs: MBPro, MacOSX 10.5.5, 4gb ram, wine-1.0
(EDIT: don't you think i am trying to render such image on mbpro, just testing, final render will go to macpro..)
does anyone have any experience with high resolution images?
Or Ono, is indigo limited in resolution?
i'd like to render something ~5000px
thanks. c
Post by Borgleader » Fri Dec 12, 2008 6:35 am
I thought the max render resolution was 10 000x10 000 or something :?
Post by fused » Fri Dec 12, 2008 7:06 am
the maximum resolution should only be limited by the amount of your ram.
FakeShamus
Post by FakeShamus » Fri Dec 12, 2008 7:28 am
I have rendered up to 7200 x 5400 on earlier versions of indigo, with similar specs to you (mac osx 10.4, wine, 4 gb ram) but I have also found that these days the newest versions have a lower res limit before they crash. that's even when using the console mode.
above about 6400 x 4800 it crashes just after finishing building all the kd trees. at 6000 x 4500 the render starts fine, then crashes when it reaches the display period (despite being in console mode not needing display anything).
the 64 bit versions should be able to handle much larger images, but those won't work with wine yet.
carbon
Post by carbon » Fri Dec 12, 2008 8:04 am
i've tried to set super_sample_factor to 1 and i doubled the resolution, that means: 2800x2800px
i was watching memory usage during indigo startup, wine took about 600 during rendering and <1100mb when saving image, any higher load caused crash
it is possibly wine issue, what you think..
Post by suvakas » Fri Dec 12, 2008 8:05 am
Also set the <super_sample_factor> to 1 for larger images (if you didn't already).
[edit]
Ok, you did, oh well.. 8)
Post by CTZn » Fri Dec 12, 2008 8:14 am
Could the diffraction post effect have an impact on that issue ? I think it's enabled by default... I'm not sure but some scene settings could possibly lead to less memory consumption (or whatever positive change they could induce). But well that's all I can tell, not a rez killer myself.
Post by CTZn » Fri Dec 12, 2008 8:45 am
Well sorry for double posting but for instance, if I launch the test scene "adaptative_diplacement_shader.igs", there is a sudden memory jump of 150 extra Mo when diffraction post filter is applied, back and forth, and the image is only 800x600...
Post by suvakas » Fri Dec 12, 2008 9:08 am
Yep, diffraction uses quite a bit of memory. The amount is related to resolution, of course.
carbon
Post by carbon » Fri Dec 12, 2008 10:38 pm
i installed ubuntu 64bit yesterday.. i was able to render 4800x4800, super sample 2, no difraction, with 4gb ram and swap file < 200mb :) so it is wine issue
FakeShamus: i recomend you to do the same :)
all: thanks for replies
Post by fused » Sat Dec 13, 2008 2:26 am
no, its just a 32 bit issue...
FakeShamus
Post by FakeShamus » Sat Dec 13, 2008 4:04 am
yeah I was gonna say, it's a 32 vs 64 bit issue. but I definitely had more success with higher resolutions with earlier versions of indigo, so I'm not convinced it doesn't still have something to do with added features or different code in the latest versions.
carbon, I'd be curious to know how you did the ubuntu installation. there seem to be different approaches, all with varying success. can you point me to what worked for you? thanks
carbon
Post by carbon » Sat Dec 13, 2008 5:53 am
fused: indigo crashed every time when using ~1.1gb of memory on wine.. so i still think it is wine issue
FakeShamus:
1. downloaded and burned Ubuntu 8.10 Desktop 64bit (ubuntu-8.10-desktop-amd64.iso)
2. attached blank drive, booted cd, installed ubuntu on blank drive, booted ubuntu, i didn't want to mess osx, so i removed all other drives
3. installed wxWidgets following this manual
4. downloaded indigo 1.1.15 64bit for linux and run
also set all diffraction to false, to save memory
Post by CTZn » Sat Dec 13, 2008 6:25 am
carbon wrote: also set all diffraction to false, to save memory
This topic inspired me the first wiki tip !
FakeShamus
Post by FakeShamus » Sat Dec 13, 2008 6:27 am
awesome, thanks!
Users browsing this forum: Bing [Bot] and 16 guests
