Black glass artefact w/o normal smoothing
Post by neo0. » Mon Nov 24, 2008 7:47 am
render @ 50 samples
Post by Kram1032 » Mon Nov 24, 2008 8:02 am
if it's without normalsmoothing, it's most probably one of those:
wrong normal direction
double / overlapping faces
Post by neo0. » Mon Nov 24, 2008 8:07 am
Well, do yo know how I could fix this in SU?
Post by neo0. » Mon Nov 24, 2008 8:45 am
Post by neo0. » Mon Nov 24, 2008 8:57 am
Would it be possible for indigo itself to check for these things and fix them in the best way possible?
Post by pixie » Mon Nov 24, 2008 9:17 am
The mesh is bad... the inner got out and the out got inner... :(
Post by Zom-B » Mon Nov 24, 2008 10:46 am
neo0. wrote:Would it be possible for indigo itself to check for these things and fix them in the best way possible?
I prefer that the lazy "artist" would gets his balls kicked each time he start bothering people instead of using his eyes to see the obvious...
Post by PureSpider » Mon Nov 24, 2008 11:12 am
+1
Post by Borgleader » Mon Nov 24, 2008 11:32 am
+1
+2
Post by neo0. » Mon Nov 24, 2008 11:54 am
Okay, einstain, tell me, what is so obvious here? I was making a simple suggestion.
Post by PureSpider » Mon Nov 24, 2008 12:12 pm
Dude, Indigo is not an "I'll fix all your fucking stupidity" program... It renders what you tell it to render, it's your duty to get your stuff right :roll:
Post by CTZn » Mon Nov 24, 2008 12:17 pm
Borgleader wrote:
PureSpider wrote:
ZomB wrote: I prefer that the lazy "artist" would gets his balls kicked each time he start bothering people instead of using his eyes to see the obvious...
+1
+2
+3, nice one Zom-B, pain may be the way for neo, after all. Indigo does check for degenerated triangles at startup time, and more. But it can not design things for you, so do things right.
neo., what you need* now is to use another 3d package in addition with sketchup, because it is a great modeling tool but will learn you nothing on 3d at all. Take whatever modeler that suits you beside sk, and you'll learn a great deal on 3d. Now, balls on the table please...
Oh and I don't know sk very well, but IIRC it's basic shader is double sided, beige outside and violet inside, isn't it ?
* this was supposed to be obvious too.
Post by Borgleader » Mon Nov 24, 2008 12:18 pm
neo0. wrote: Okay, einstain, tell me, what is so obvious here? I was making a simple suggestion.
1. Its Einstein not einstain
2. Pixie nicely said it earlier "the inner got out and the out got inner". Soo... keep the inner inner and the outer outer...this is what's so obvious here.
Post by neo0. » Mon Nov 24, 2008 12:28 pm
I wasn't asking it to design things for me. This is simply another error, like degenerate triangles that it could warn you about.
Sketchup isn't my modeller. The only reason why I use it is to export to indigo. I use Hexagon and Wings.
Sorry, bro, I don't swing that way.
Post by CTZn » Mon Nov 24, 2008 12:38 pm
Fair enough.
