Controlling Light Intensity?
4 posts • Page 1 of 1
U238
Post by U238 » Fri Nov 14, 2008 4:46 pm
This may be a stupid question but how do I control a meshlight's intensity? Everything I've rendered with indigo using meshlights has a horrible glare from too much lighting? Is it something right under my nose in blendigo? Or is it adjusted through the xml file?
Thanks in advance.
Gog
Post by Gog » Fri Nov 14, 2008 10:17 pm
select the mesh light, then in blendigo go to the material tab,
There is a power and efficacy setting for the light next to the material colour setting.
U238
Post by U238 » Sat Nov 15, 2008 3:38 am
I messed with those settings and neither of them appeared to really do anything. What exactly are each of those settings supposed to do? (Manual wasn't much help)
I assume the power controls how strong the light is by default and efficacy is the "volume" knob?
Gog
Post by Gog » Sat Nov 15, 2008 4:06 am
Power is how much energy you put in efficacy you can treat as how efficient the source is at converting power to light
There's a handy table at wikipedia http://en.wikipedia.org/wiki/Luminous_efficacy
