Found unexpected element 'specular_reflectivity' in element
11 posts • Page 1 of 1
delle
Post by delle » Wed Sep 17, 2008 8:39 pm
Hi, when I use the following material, I get this error:
Fatal Error: IndigoDriverExcep: SceneLoaderExcep: Found unexpected element 'specular_reflectivity' in element 'phong'
What is wrong?
Thanks
<material>
<name>Material_16</name>
<phong>
<specular_reflectivity>
<constant>
<rgb>
<rgb>0.3 0.3 0.3</rgb>
<gamma>2.2</gamma>
</rgb>
</constant>
</specular_reflectivity>
<exponent>3000</exponent>
<fresnel_scale>1</fresnel_scale>
</phong>
</material>
Post by fused » Wed Sep 17, 2008 8:46 pm
which exporter do you use?
looks like its mixing up old and new style mats. the ior is missing, too.
i think correct is:
    <material>
        <phong>
            <ior>1.35</ior>
                <constant>
                    <rgb>
                        <gamma>2.2</gamma>
                    </rgb>
                </constant>
            <exponent>
                <constant>62.5</constant>
            </exponent>
        </phong>
    </material>
Post by Zom-B » Wed Sep 17, 2008 9:47 pm
A classic issue of uncompatible Indigo & exporter versions... :roll:
Post by pixie » Wed Sep 17, 2008 10:08 pm
So cliche! :lol:
delle
Post by delle » Wed Sep 17, 2008 11:55 pm
Hi, I'm trying to write an exporter for my program.
So I'm trying to simulate my materials with Indigo materials.
Doing so, I'm using info from everywhere (Indigo Manual, Google, Material database, ...)
:oops:
Thank you!
Post by PureSpider » Wed Sep 17, 2008 11:56 pm
Which program? ;)
delle
Post by delle » Thu Sep 18, 2008 12:15 am
This program...
Realtime OpenGL preview on a GeForce 6600
:lol:
Post by fused » Thu Sep 18, 2008 2:30 am
nice! if you need any help just ask!
about the materials: i'd stick to the specs defined in the latest manual.
i'd also be careful with the materials in the matdb - they are not validated in any way.
Post by pixie » Thu Sep 18, 2008 2:32 am
Mine are... they indigo stamp of quality (they are pigmed on indigo)
Post by fused » Thu Sep 18, 2008 2:40 am
true. pigms packed by indigo should be correct.
easyarchitect
Re: Found unexpected element 'specular_reflectivity' in element
Post by easyarchitect » Mon Apr 06, 2020 5:00 am
Fixed my exporter !
...after so may years...
Bye
Antonio
<material> <!-- IgsMaterialType : "IgsSpecular" -->
    <name>Material_50_Reflectivity</name>
    <phong>
      <constant>
        <rgb>
          <rgb>1 1 1</rgb>
          <gamma>2.2</gamma>
        </rgb>
      </constant>
    <exponent>
      <constant>990040</constant>
    </exponent>
      <texture>
        <!-- TextureMap[0] : "Mappa riflessi ambientali" -->
        <uv_set>default</uv_set>
        <path>.\CUCINA BRICCOLA 2\PALOALTO_GRAY_ALPHA1.bmp</path>
        <exponent>2.2</exponent>
        <b>1</b>
        <c>0</c>
      </texture>
      <diffuse_albedo>
        <constant>
          <rgb>
            <rgb>1 1 1</rgb>
            <gamma>2.2</gamma>
          </rgb>
        </constant>
      </diffuse_albedo>
      <ior>1.820000</ior>
      <exponent><constant>990040</constant></exponent>
      <fresnel_scale>0.900000</fresnel_scale>
    </phong>
  </material>
  <material>
    <name>Material_50</name>
    <blend>
      <a_name>Material_50_Specular</a_name>
      <b_name>Material_50_Reflectivity</b_name>
      <blend>
        <constant>0.640000</constant>
      </blend>
      <step_blend>false</step_blend>
    </blend>
  </material>
