Indigo fatal error
14 posts • Page 1 of 1
Indigo fatal error
Post by neo0. » Fri Sep 12, 2008 5:33 pm
It says that it found an unexpected element in "lens shift shift up distance" in the camera element. :?
Maybe for a future release, it could give you some hints on how to fix these errors?
Big Fan
Post by Big Fan » Fri Sep 12, 2008 6:05 pm
@neoO
on behalf of all labouring export writers I have to say that is a useless post
I get tired of seeing these one line descriptions of errors and people expecting to get effective help from that
if you really think you have an issue in the first instance reply to your exporter forum stating some helpful information like what versions of the exporter and indigo you are using etc.
if you are quoting correctly there, there is a mistake in that exporter in that 'shift' is stated twice
it is up to the exporter writer to fix that or alternatively if you want in this case, open the .igs in Notepad and edit the line with that in it to look like this
	<lens_shift_right_distance>0.000000</lens_shift_right_distance>
		<lens_shift_up_distance>0.002000</lens_shift_up_distance>
note that I quoted both shift statements in case they are wrong
please think about what you are posting
how high is a chinaman... :roll:
cpfresh
Post by cpfresh » Fri Sep 12, 2008 6:18 pm
my guess is mis-matched indigo/skindigo versions...? like big fan said, a little more info would be helpful.
Post by neo0. » Fri Sep 12, 2008 6:35 pm
Sorry, but that's because the error was a one liner too.
Indigo version : 1.9.02
Skindigo Version : SkIndigo 1.1.8
Basically, latest versions of both.
I read in the sketchup forum, that 1.1.8 was compatible with the latest v of indigo
its been a bitter past.JPG (21.96 KiB) Viewed 10883 times
Big Fan
Post by Big Fan » Fri Sep 12, 2008 7:09 pm
well there you go - you didnt even quote the error correctly let alone tell us what you were using :roll:
now we know that much I'll let a Skindigo user answer it 8)
cheers BF
EDIT:
ok wait I've got my good samaritan hat on and actually I see at the bottom of page 1 of the Skindigo1.1.8 thread what appears to be exactly the same error and on p2 the solution. wow! what a bit of luck :wink:
Post by PureSpider » Sat Sep 13, 2008 8:54 am
neo0. wrote:Sorry, but that's because the error was a one liner too.
:roll: :cry:
May I slap him please? I mean finally he deserves it somehow :evil:
Post by CTZn » Sat Sep 13, 2008 10:36 am
Sure, I'm not there.
Post by neo0. » Sat Sep 13, 2008 11:03 am
:roll: :cry:
Im sorry, you're not helping at all CTzn.
Post by PureSpider » Sat Sep 13, 2008 11:08 am
Guy it's been told like a THOUSAND times that you only should use the corresponding versions of the exporter and indigo...
How could Indigo 1.0.9 recognize commands first introduced in 1.1.8 or even later?
It's like... trying to read DVDs with your CD player and wonder why it won't work -.-
I'm just that upset 'cause you ask the same questions that have already been answered sufficent times over and over again...
USE THE BOARDS SEARCH GODDAMNIT!
Post by neo0. » Sat Sep 13, 2008 12:04 pm
Uh, im pretty new here as it turns out. From the point of view of a newbie, thre could be hundrds of potential issues.
Moreover, this version of skindigo was released as a test version, so why are you blaming people for reporting errors?
Post by Kram1032 » Sat Sep 13, 2008 6:57 pm
This Version of SKindigo, yes... but did you check the Version of Indigo?
Post by PureSpider » Sat Sep 13, 2008 9:54 pm
Check my join date of the forums... and... why do you think I don't ask newb questions?
Maybe because I use the board search/logical approach BEFORE asking questions?
Post by fused » Sat Sep 13, 2008 10:49 pm
edit: nvm, ill pm you PureSpider.
Trebawa
Post by Trebawa » Thu Sep 25, 2008 1:33 pm
I have the same problem as neo0. I am using SkIndigo 1.1.8, which is reported to work with Indigo 1.1.9, which I am using. I would appreciate any possible help. The only line containing "lens_shift_up_distance" in the Ruby script is as follows:
out.puts "			<lens_shift_up_distance>#{@irs.shift_up.to_f/1000.0}</lens_shift_up_distance>"
out.puts "			<lens_shift_right_distance>#{@irs.shift_right.to_f/1000.0}</lens_shift_right_distance>"
out.puts "		</camera>"
Thank you.
