Indigo 1.1.10
Indigo 1.1.10
Post by OnoSendai » Tue Sep 09, 2008 12:00 am
win32:
http://www.indigorenderer.com/joomla/in ... &Itemid=62
win64:
changelog:
1.1.10
* added comparison functions to shader language:
eq, neq, lt, lte, gt, gte
* added boolean functions to shader language:
and, not, or
* added length function for vectors to shader language
* messed around with shading normals a bit.
* fixed lightSourceInserted()
* added .igmesh binary mesh support.
* narrowed tonemapping panel on GUI a bit.
EDIT: attached latest manual, which contains documentation for new shader language functions, and emission_scale.
Indigo Manual.zip
(1.9 MiB) Downloaded 688 times
mrmoose
Post by mrmoose » Tue Sep 09, 2008 12:54 am
Thanks Ono :wink:
Big Fan
Post by Big Fan » Tue Sep 09, 2008 1:05 am
in laymans terms that means photometric works in the UI again among other things :D
and the exception handling for no light source is sorted :wink:
thanks for the UI diet too :P
EDIT: might have spoken too soon about IES :? it worked twice.. odd problem :(
WytRaven
Post by WytRaven » Tue Sep 09, 2008 1:10 am
Argh! Where's SmartDen when you need him :(
Big Fan
Post by Big Fan » Tue Sep 09, 2008 1:14 am
on holiday away from the maddening crowds of demanding blendigoists - lucky fellow
btw mr raven did you see I put your lens sets/ correction in there?
probably not quite what you wanted but I did do it...
rgigante
Post by rgigante » Tue Sep 09, 2008 1:15 am
Thanks Ono! Got it... let's goin' test .igmesh 8)
WytRaven
Post by WytRaven » Tue Sep 09, 2008 1:25 am
Big Fan wrote:on holiday away from the maddening crowds of demanding blendigoists - lucky fellow
I haven't tried out your version yet BF. Will do when I get a half a chance cause I am keen to see whats new in indigo.
Post by pixie » Tue Sep 09, 2008 2:05 am
igmesh should mean a major speed bump in cindigo!!! :D
Pinko5
Post by Pinko5 » Tue Sep 09, 2008 2:58 am
Tnx ONO!!!
Luca. ;)
Post by Zom-B » Tue Sep 09, 2008 2:59 am
Thanks a lot Ono!
Does anybody know some lecture/tutorial that would help to understand and use Indigos Shader Language better? The main Problem is about the understanding of some basic 3D stuff that the language is referring to :/
rgigante
Post by rgigante » Tue Sep 09, 2008 3:45 am
By my side... .igmesh support works like a charm here with single UV set!
And YES! U messed very well with shading normals! Bump bug being still visible is much less evident!
Regards, Riccardo.
tacos
Post by tacos » Tue Sep 09, 2008 3:59 am
thank's
zsouthboy
Post by zsouthboy » Tue Sep 09, 2008 5:05 am
Thanks as always, Ono.
Slavn
Post by Slavn » Tue Sep 09, 2008 5:12 am
Thank You very much, master Ono.
cpfresh
Post by cpfresh » Tue Sep 09, 2008 6:24 am
AWESOME!! Thank you Ono! :)
