indigo for 3d max 9 32bit(indigo gira su 3d max9 a 32bit)
indigo run on 3d max9 32 bit?
you excuse my English
indigo gira su 3d max 9 a 32 bit?
on 3d studi max 9 32 bit indigo it's ok
indigo gira su 3d max 9 32 bit..
cioa grazie
cioa grazie
- Adam Guzowski
- Adam Guzowski
yes!!
yes, u3dreal, your exprter run on 3d studio max 9 32 bit!!!It work very well.
I believe that it work better on 3d studio max 9...
it excuses my English
filippo
si, il tuo exporter lavora bene su 3d studiomax 9 32 bit, forse anche meglio di prima.
ciao
filippo
ciao
ThanksAdam Guzowski wrote:yes!
work very well.
Im using 3dsmax9 64bit version and XP 64bit (lots of RAM for architectural visualisation)... soon I share some of my works made in indigo with a great communication by Your exporter.
Superb work mate
thanks
good to hear it also works on 64bit version... some had problems..
did you use any other install or just like afecelis showed in his tutorial ?
cheers
u3dreal
- Adam Guzowski
I try to use Indigo renderer since 0.4 release but I am a very busy man.Architecture can be very time-consuming and never had enough time to play with installation process and writing XML files for my scenes.
Since I found this "afacelis" tutorials I start to play with indigo once again.
So far I didnt found any serious bugs or crashes using Your tool.
u3dreal If You need a pure dualCPU 64bit machine for some tests write a PM.
Okie will do if so...Adam Guzowski wrote:I try to use Indigo renderer since 0.4 release but I am a very busy man.Architecture can be very time-consuming and never had enough time to play with installation process and writing XML files for my scenes.
cheers
u3dreal
