Rendering over the internet
6 posts • Page 1 of 1
Thexa4
Post by Thexa4 » Fri Aug 08, 2008 12:45 pm
I am trying to render a scene with a master and a client.
The server was started using this code:
indigo "scene/indigo_gpu.max-scene.igs" -n m -p 29500
The clients are launched using this code:
indigo -n s -h ip:29500
This works as long as the scene is in exactly the same folder on the computer that runs the client.
The problem is that indigo doesn't transfer the scene to the clients when indigo cannot find it.
Is there a way to solve that?
Post by CTZn » Fri Aug 08, 2008 1:13 pm
Indigo 1.0.9 I must precise.
Thexa4
Post by Thexa4 » Sat Aug 09, 2008 11:44 pm
I got it to work with version 1.1.8, this post can be locked
Post by CTZn » Sun Aug 10, 2008 12:48 am
Posts are never locked here :)
:shock: Really really ?
ViennaLinux
Post by ViennaLinux » Mon Aug 11, 2008 6:48 pm
indigo 1.1.7 transfers (packed) indigo scenes for you.
thank you so much Ono :-)
Post by CTZn » Tue Aug 12, 2008 3:19 am
Yes, scene transfer was not an issue (and we used simple scenes for testing, from testscenes folder). Frame transfer was a biiig issue :)
aslocum asked for "delta" compression for frames... dunno what this is but any sort of frame compression would help a great deal here.
