Trying Network rendering ... many problem
Indigo 1.0.9
Master : Ubuntu
Computer name : lo-desktop
Sharing rep on master : indigo_render
Slave : Xp
computer name : xp_ordi
On my master trying :
wine indigo_console.exe //lo-desktop/render_indigo/test_cube1.igs -n m
And i have got this problem message :
Indigo Renderer v1.0.9, Windows 32-bit Release build.
Failed to open scene file '//lo-desktop/render_indigo/test_cube1.igs' for reading.
Fatal Error: Failed to open scene file '//lo-desktop/render_indigo/test_cube1.igs' for reading.
I think it's a network problem.
Master : Ubuntu
Slave : Xp
- Borgleader
I'm haven't any clue about Linux, but after 1001 successful Windows based network rendering approaches I can say that for least @ a windows system the port you want to connect is important too (maybe for wine too!?)!
Master
Slave
wm my the way starts a master that also do rendering
Master
cd indigo_v1.1.5
START /B /LOW indigo.exe \\hauptrechner\netrender\netrender.igs -n wm -p 7777Slave
cd indigo_v1.1.5
START /B /BELOWNORMAL indigo_console.exe \\hauptrechner\netrender\netrender.igs -n s -h hauptrechner:7777polygonmanufaktur.de
Can't find my share rep on windows xp console...zsouthboy wrote:?
So now your xp machine can't see the exact same file that was working before?
Maybe try copying the .igs and all related textures to both sides locally and forget the UNC path.
SO i tried a linux version and then another problem :
lo@lo-desktop:~/telechargement/indigo_linux_v1.0.9_2$ ./indigo_console /mnt/render_indigo/test_cube1.igs -n m
Indigo Renderer v1.0.9, Linux 32-bit Release build.
Starting server on port 7777...
Using base Indigo directory path '.'.
Scene file path: '/mnt/render_indigo/test_cube1.igs'
Using working directory path '/mnt/render_indigo'.
Loading Scene '/mnt/render_indigo/test_cube1.igs'...
Using Reinhard tone mapping with pre_scale=4.000000, post_scale=1.200000, burn=6.000000
Instruction illégale (core dumped)
ok... then i succed some stuff..
1 - I made my share rep on my ubuntu, with my igs_file.igs for me :
/home/lo/telechargement/render_indigo ( right clik and share..)
2 - I mount acces to this rep
first a little test
then mount on mnt my share rep with root access :
Then run indigo with indigo_console :
the master (on console on my ubuntu) :
the slave (on console on my ubuntu to run first render machin) :
Then i tried to run a slave render to my windows xp on my network.
First : made windows access to my share rep on a dos console windows
i used net start :
then when i made cd t: on my dos console and make dir, i see the list of my render_indigo rep with my test_cube1.igs
Then i have acces to my test_cube1.igs file and can edit it ( edit t: test_cube1.igs is ok), but when i tried :
connected to master ok then
ive got an error message, can't reading test_cube1.igs
what the problem here ?
first a little test
:~$ smbclient -L lo-desktop
Password:
Domain=[LO-DESKTOP] OS=[Unix] Server=[Samba 3.0.26a]
Sharename Type Comment
print$ Disk Printer Drivers
iP4300 Printer Canon iP4300
render_indigo Disk
IPC$ IPC IPC Service (lo-desktop server (Samba, Ubuntu))
Server Comment
Workgroup Master
LORESEAU LO-DESKTOP
~# smbmount //lo-desktop/render_indigo /mnt/render_indigo -o username=lo
Password: the master (on console on my ubuntu) :
wine indigo_console.exe /mnt/render_indigo/test_cube1.igs -n m the slave (on console on my ubuntu to run first render machin) :
wine indigo_console.exe /render_indigo/test_cube1.igs -n s -h lo-desktop:7777Then i tried to run a slave render to my windows xp on my network.
i used net start :
net start t: \\192.168.0.11 \render_indigo Password /user:lo
indigo_console.exe t:test_cube1.igs -n s -h lo-desktop:7777ive got an error message, can't reading test_cube1.igs
