What should I bevel?
4 posts • Page 1 of 1
paco
Post by paco » Mon Jul 07, 2008 9:45 pm
I'm working on an interior scene -walls, stairs, etc. In order to make the scene more realistic i've read that I should bevel edges. I have a couple of questions:
1) should I bevel EVERY edge, or just those closest to the camera?
2) I take it that I need to bevel the edge, and then set the mesh to smooth? I read somewhere that blendigo cannot handle a mesh with smooth/ non-smooth components - is that true? How do I get around this?
Any help appreciated!
palawat
Post by palawat » Tue Jul 08, 2008 5:20 pm
1. For me, I'd bevel just the ones that hurts the render not all of them. But for experimental or perfectionism sake, you can always try bevel all of them :wink:
2. "Set smooth" to object still gives weird result. Try using "Subsurf" instead.
Hope this help.
Cheers,
Stur
Post by Stur » Tue Jul 08, 2008 8:09 pm
If you want a smooth object with some sharp edges, the better is to add a subsurf modifier, then an edge split modifier.
About beveling, I second Palawat.
paco
Post by paco » Mon Jul 21, 2008 9:19 am
Thanks for the replies! The scene i'm working on is at:
http://www.indigorenderer.com/joomla/fo ... 8937#58937
I ended up beveling the stairs but didn't bother with the walls. I'm guessing beveling is most noticeable on reflective materials (ie, with highlights). I did try the walls at one stage but I couldn't tell the difference.
Users browsing this forum: No registered users and 77 guests
