Hi!
I'm rendering a simple wallpaper 1280x800 with a plane and two spheres.
With a different HDRI in the past i've a good image after 6-7 hours.
now after 20 hour rendering this is the result.
It's normal?
Thx
Dox
Something strange in this scene
danyolgiax
- Rendering
- im1213209642.jpg (49.02 KiB) Viewed 8799 times
- sceneAndPlane.jpg (94.05 KiB) Viewed 8799 times
- spheres.jpg (50.14 KiB) Viewed 8799 times
(Blender 2.46, Indigo 1.1.5, Blendigo 1.1.5)
danyolgiax
danyolgiax
danyolgiax
Yes it was an HDRI problem! This is the same scene with a different HDRI rendered in 4 hours... it's better than the previous rendered in about 20 hours!!
In the second image now I've a strange effect (marked in red) and I cannot say if it's an artifact or is a normal glass reflection... what do you think?
Dox
Dox
- New scene with different HDRI
- im1213786503.jpg (25.79 KiB) Viewed 8494 times
- Strange reflection
- im1213786503_2.jpg (13.85 KiB) Viewed 8494 times
As far as I can see, its the horizont line flipped exactly like it should be.danyolgiax wrote:In the second image now I've a strange effect (marked in red) and I cannot say if it's an artifact or is a normal glass reflection... what do you think?
if you would try other (none reflecting) ground mat, you'll see it much better (checker for example).
