SkIndigo 1.0.9 Official
Download SkIndigo 1.0.9 Official here.
Use this version with Indigo 1.0.9 (1.0 Stable).
INSTALLATION
1. Remove any previous versions of SkIndigo from your SketchUp/Plugins directory
2. After unzipping the file you downloaded, you should have a file called 'Skindigo.rb', a folder called 'SkIndigo', and another folder called 'SUpreviews'
3. Copy 'SkIndigo.rb' into your SketchUp/Plugins directory
4. Copy the 'SkIndigo' folder into your SketchUp/Plugins directory
5. Copy the 'SUpreviews' folder to your Indigo directory
6. Run SketchUp
#Version 1.0.9 Official
#Fixed: sphere primitive with no material bug
#Fixed: monochrome render bug
INSTALLATION
6. Run SketchUp
Thank you Dale!
some of test with ies light at sketchucation - http://www.sketchucation.com/forums/scf ... =15&t=9596
i got nice results with BdirMLT...because it normally supports black evironment
I tried with no-bdir types, but sky(illumation) was visible...need more night-dak evironment
if i missed something, does indigo or skindigo support 2-sided mats(for lights)?
- testi.zip
- skp scene +ies file
- (96.88 KiB) Downloaded 520 times
- im1210436681_BdirMLT.JPG (138.54 KiB) Viewed 30781 times
Re: SkIndigo 1.0.9 Official
What do you mean by this?Whaat wrote: #Fixed: sphere primitive with no material bug
http://www.indigorenderer.com/joomla/fo ... php?t=3972Pibuz wrote:What do you mean by this?Whaat wrote: #Fixed: sphere primitive with no material bug
- kwistenbiebel
I'll try to throw a quick and dirty release together to get people up and running with some of the new features (you probably won't get everything at once). I'll probably do some work on it tonight.kwistenbiebel wrote:Hi Whaat,
[While bowing humbly before the master]: "Could we have a 1.1.1 Skindigo version pppppppppppplease?"
Don't forget that you can access all of the new features by manually editing your IGS file after exporting.
- kwistenbiebel
