proble with maxigo 1.09.6
11 posts • Page 1 of 1
tacos
Post by tacos » Wed Apr 09, 2008 12:38 am
i've render a my old scene and i've a problem with maxwigo 1.09.6 with render region...
tacos
Post by tacos » Wed Apr 09, 2008 12:45 am
2° image
tacos
Post by tacos » Wed Apr 09, 2008 12:46 am
3..
tacos
Post by tacos » Wed Apr 09, 2008 12:51 am
excuse for my English
Post by suvakas » Wed Apr 09, 2008 1:11 am
What is the problem exactly?
Too bright image? Don't use Reinhard tomenaping with region rendering.
tacos
Post by tacos » Wed Apr 09, 2008 1:21 am
I make a test, thank's
tacos
Post by tacos » Wed Apr 09, 2008 2:05 am
i've make a test but the result no good!!
i've make two render: the first normal and the second without tonemapping
tacos
Post by tacos » Wed Apr 09, 2008 2:06 am
and this is the setting
Post by suvakas » Wed Apr 09, 2008 2:27 am
The initial image must also use the same settings as the one with a region.
So you also can't use reinhard for the big image too. Otherwise your settings would be different and the brightness of the output would also be different (as seen on your images). Set tonemaping to None for both and tweak your brightness by using the F-stop, ISO, Shutter etc.
Kosmokrator
Post by Kosmokrator » Wed Apr 09, 2008 2:29 am
i think its ok with out the reinhard function!!what exactly is your problem?i work with new exporter for a few hours and looks quite stable and bug free....
tacos
Post by tacos » Thu Apr 10, 2008 6:21 am
i've make the big image with Reinhard tomenaping and in the little image i've disattive the Reinhard tomenaping.. I wanted to know if also in the great image it must be without tonemapping
