Blendigo for v1.0.9
Blendigo for v1.0.9
Requirements:
- Blender 2.45
- Python 2.5
- Indigo v1.0.8 or 1.0.9
Installation:
- Place Blendigo in ./blender/scripts
- Dont forget to edit IndigoWrapper.conf to specify your indigo location and put it in ./blender/scripts/bpydata
- put preview in the indigo directory
or use installer
Blendigo is continue developing
Update 23.05.2008
- External material support fixed
- "Auto Choose Thread" button added
- "Override" button added
Update:
- Linux build will be started with GUI
Bug Fix:
- DupliVerts and DupliFaces objects will be exported as instances
- Sphere and Plane primitives work now
- Bump export for Oren-Nayar shader
Windows Installer Blendigo_v109.exe
Zip blendigo_v109.zip
Skript for manually update blendigo_v109.py
- Blender 2.45
- Python 2.5
Installation:
or use installer
Update 23.05.2008
Update:
Bug Fix:
Check normals, dude!
... Normal was not unit length. fixed?
greetz,
jur
after 'remove doubles' it's ok.<vertex pos="-4.141155 -1.603915 0.000000" normal="nan nan nan" />
greetz,
jur
- normal_error.zip
- .igs and .blend
- (286.13 KiB) Downloaded 982 times
- aleksandera
.sphere primitive doesn't work for me.
ALso, using 'export to animation' doesnt want to work
exporting object "Sphere.sphere"
material [Material "Phong"] found
File "<string>", line 3010, in buttonEvt
File "<string>", line 2325, in exportStill
File "<string>", line 2303, in export
File "<string>", line 2181, in exportIndigoScene
File "<string>", line 1713, in exportObjects
File "<string>", line 1638, in exportObject
File "<string>", line 1429, in getBoundingBox
TypeError: 'Blender MVert' object is unsubscriptableALso, using 'export to animation' doesnt want to work
INDIGO EXPORT
start 1 end 10
exporting frame 1
Object Sphere in layer 1
Object Plane in layer 1
Object Lamp in layer 1
Object Empty in layer 1
Object Camera.001 in layer 1
Object DonutTurd in layer 1
exporting object "Sphere"
File "<string>", line 2944, in drawGUI
File "<string>", line 965, in materialGUI
File "<string>", line 2976, in drawButtons
File "<string>", line 2949, in drawScreenButtons
File "<string>", line 2328, in exportAnim
File "<string>", line 2270, in export
File "<string>", line 1630, in exportObject
AttributeError: 'str' object has no attribute 'write'-
pixelminer
I can't export out animations either.
I can verify that the "export to animation" button gives the same errors as listed below.
bummer...
phong.
bummer...
phong.
neepneep wrote:
ALso, using 'export to animation' doesnt want to work![]()
Traceback (most recent call last): File "<string>", line 2944, in drawGUI File "<string>", line 965, in materialGUI File "<string>", line 2976, in drawButtons File "<string>", line 2949, in drawScreenButtons File "<string>", line 2328, in exportAnim File "<string>", line 2270, in export File "<string>", line 1713, in exportObjects File "<string>", line 1630, in exportObject AttributeError: 'str' object has no attribute 'write'
