MtI v1.0.9 Stable (updated 17th April 2008)
dougal2
Post by dougal2 » Fri Mar 28, 2008 9:12 am
No major changes over 1.0.8, except for adding a couple of renderer settings in the scriptnode.
UPDATE 9th April 2008
See this post for an update: Mti 1091
UPDATE 11th April 2008
There is now an installer for MtI for windows platforms here:
http://indigomaterials.uk.to/downloads/ ... Indigo.exe (94k)
(You will need to install Indigo (1.0.9 stable) and Maya (7/8/8.5/2008/2008x64) before installing MtI.)
UPDATE 15th April 2008
There is now an installer for MtI for linux platforms here:
http://indigomaterials.uk.to/downloads/ ... er-1091.sh (160k)
NB: you may have to "chmod +x" the .sh file before you can run it in a bash terminal. It is a self-extracting archive and installer script. Should be fairly straightforward :)
UPDATE 17th April 2008
Linux installer has been updated to fix a number of bugs.
MayaToIndigo-v 1.0.9Stable.zip
(210.57 KiB) Downloaded 5671 times
dougal2
Post by dougal2 » Tue Apr 08, 2008 12:06 pm
hmm, 120 downloads and nobody has anything at all to say about it.
I guess I'll take that as a compliment :D
seriously though, I'd like to hear some kinda feedback from MtI users, either good or bad... there may well be bugs or missing features that you guys could use. Just let me know and we'll see about adding more stuff to MtI.
(Although, I kind of agree with the philosophy that perfection is achieved not when there's nothing more to add, but when there's nothing more to take away :) )
Any feedback at all would be appreciated.
Phr0stByte
Post by Phr0stByte » Tue Apr 08, 2008 11:59 pm
dougal2
I will let you know, but I havnt downloaded it yet. Still modeling - How I wish for 42 hour days....
bkircher
Post by bkircher » Wed Apr 09, 2008 5:26 am
Hi Dougal,
I haven't found time to contribute lately (and when I did find some time, the job was already done by you :).
Thanks a lot for
- keeping things running,
- implementing every feature in no time,
- and most of all: For writing this extremely tidy code.
regards,
b
btw., 120 downloads is something like exponential growth of downloads...
Some tiny things I'll do when I have a working Maya machine running with SVN again:
- Bring the Help Menu "Table" more up to date, so the meaning of all the (legacy) maya shaders
parameters is visible on first glance
- Add Oren-Nayar shader through anisotropic
- Fix some Icons
- Add a Meaningful preset for every element
- Power drawn or Luminous efficacy is fixed at 2, should be fixed at one so the math is simpler
dougal2
Post by dougal2 » Wed Apr 09, 2008 6:12 am
OK, I've set luminous_efficacy to 1 in my working copy.
I've also added a sanity check if you've forgotten to set power drawn (I do this quite often :oops: ) and it gets set to 20.
I'm also working on the time/date sun functions - I know it's not techincally anything to do with Indigo, but there's no harm in having it in ;)
Post by OnoSendai » Wed Apr 09, 2008 7:10 am
I think you got 120 downloads and no comments because I added it to the main download menu with a direct link.
Phr0stByte
Post by Phr0stByte » Wed Apr 09, 2008 7:12 am
dougal2
I didn't think we had 120 Maya users... I have yet to download it.
dougal2
Post by dougal2 » Wed Apr 09, 2008 7:21 am
true, it'd be nice if those people would join the forum though :)
Post by OnoSendai » Wed Apr 09, 2008 7:22 am
Indeed dougal. Perhaps I'll add links to the relevant forum posts to the main download page.
dougal2
Post by dougal2 » Wed Apr 09, 2008 7:26 am
MtI update:
I've got the Geo-Sun working, I'm using the routines from the GeoSun script on highend3d.com instead of the algorithm I posted in the other forum.
I'll commit changes later this evening.
dougal2
Post by dougal2 » Wed Apr 09, 2008 8:24 am
Short sun animation:
http://ftlfm.com/gallery/v/indigoAnim/suncycle.flv.html
The world location is set to London, date is today's date. So basically this is a render of what shadows looked like here today :)
The GeoSun stuff is now available via the SVN. To use it, run
mti_setupGeoSun
and you'll find the time/date/location settings in the Extra Attributes section of the sunShape directional light.
dougal2
Post by dougal2 » Thu Apr 10, 2008 8:21 am
Mostly changes for linux compatibility:
- Added option to run indigo native or indigo wine version
- Added option to change indigo's "nice" value when run
- Added GeoSun functions to the Sun button - look in "Extra Attributes"
MayaToIndigo-20080409.zip
(214.56 KiB) Downloaded 372 times
Phr0stByte
Post by Phr0stByte » Fri Apr 11, 2008 2:00 pm
dougal2
Well, after about 3 hours, I finally got it working, so you can ignore my PM. I still cant get it to start the render direct - just get the xml exported - no biggie. And for the life of me, I cannot figure out why the icons wont display still. LOL
All in all, great stuff, dougal. How about some install scrips? One for Win and one for Lin. It could take a lot of the guesswork out of it... I could help with the Linux shell script for install, but I'm almost certain that I have never gotten it installed just right. Have you known anyone else to use Maya natively in linux along with the script? Maybe I'm the odd one out...
dougal2
Post by dougal2 » Fri Apr 11, 2008 11:17 pm
OK, I'm up for doing installer scripts. Off the top of my head there are only 2 variables we need to know up-front:
1. The user's home directory
2. The Maya version
The first I think we can get quite easily using an environment variable in windows (%USERPROFILE%) and using ~/ in linux.
(Actually, reliably determining the location of "My Documents" might be tricky - I for one have changed it on at least one of my machines, and Vista has a different name for it! :x )
The second can be prompted for.
linux:
OPTIONS="7.0 8.0 8.5 2008 8.5x64 2008x64"
select opt in $OPTIONS; do
  if [ "$opt" = "7.0" ]; then
    MAYA_VER=7.0
    break
  elif [ "$opt" = "8.0" ]; then
    MAYA_VER=8.0
    break
  elif ..
....etc.....
  else
    echo bad option
  fi
done
windows:
echo Enter maya version:
set /p maya_ver=
Then it's a case of copying a few files to folders, with the exception of adding a little data to the Maya.env file -but only if it doesn't already exist!
MyPath = D:\Documents\maya\8.5
MyScriptPath = %MyPath%\scripts
MAYA_SCRIPT_PATH = %MyScriptPath%\MayaToIndigo
MAYA_PLUG_IN_PATH = %MyScriptPath%/indigoShader
the MAYA_*_PATH vars also need to not destroy any parts that existed before.
Interesting idea, most of the parts to do it are here in this post.
Phr0stByte
Post by Phr0stByte » Fri Apr 11, 2008 11:29 pm
dougal2
Yes, like I said, I dont think it would be hard to do - I just dont want to start something like that when I think I am installing it wrong anyway. I think this because certain things have never worked for me, such as the icons and direct rendering.
