It doesn't look much different to how it looked 8 hours ago........
Noobie. Will render continue until image is totally clear???
Ive been rendering my first image with Blendigo for 10hours and 46 mins so far, and it still has a grainy look to it. Will the render continue until a point at which it says it has finished or will it just keep trying to render until I stop it.
Big Fan wrote:well the nature of indigo is you can just keep until you are happy with it![]()
it depends on a number of things how fast its going to clear up
hardware speed , materials, size of image...
1280 x 1024.how about you post some details and a wip image so we can tell you more about it![]()
Athlon 64 3200
- First render with no textures
2 hours or so. - im1205183451.png (1.5 MiB) Viewed 5534 times
- render has approx 12 textures.
11 hours - im1205352271.png (2.47 MiB) Viewed 5534 times
You can stop now and use a .nk data for the swords.
http://deeppixel.uw.hu/projects/NK_materials.html
You're going to wait 30 hours
Rendering on a single core Processor as you do, will take some time
Maybe you got some other Computers @ home that could join via network rendering, also over the Internet via Hamachi is a option!!
If you got Hybrid mode activated, try to deactivate it for the next time...
Your scene is quite nice, some optimization and you got a really nice piece of art done
For Example the black borders, good visible on the untextured version are normal smoothing issues! Subdivide your edges more, or control smoothing by angle on the critical objects...
Reduce the overall IOR you are using for the materials, and enhance the ground texture (and the other looooow res textures) some bump maping could be nice too
I hope to see this scene
Thanks to all for the replies.
I was more worried that I might be waiting for it to get better and due to other settings it might not have, and therefore after 20 hours might have looked the same as it did after 2 if you see what I mean.
I haven't worked out how to get the right lighting yet either. I wanted it to be much darker with the exception of sun rays shining in through the skylights above the swords giving it a hazy effect.
Also I wanted the objects behind the swords to be ever increasingly out of focus.
Still so much to learn
Thanks for that i'll look into itVanessa07 wrote:You can stop now and use a .nk data for the swords.
You're going to wait 30 hours Laughing
Im not worried to be honest of the rendering time, im doing it at home and I leave it rendering in the background. It doesn't slow down anything else im doing. I just leave it going overnight.ZomB wrote:Rendering on a single core Processor as you do, will take some time Sad
Ok I will do. ThxZomB wrote:If you got Hybrid mode activated, try to deactivate it for the next time...
Thx. Im fairly new to Blender too, so have a lot to learn there. but doing things like this is a great way to learn your way around it.ZomB wrote:Your scene is quite nice, some optimization and you got a really nice piece of art done Smile
Reduce the overall IOR you are using for the materials, and enhance the ground texture (and the other looooow res textures) some bump maping could be nice too Wink
