So..this time it isn't really Indigo that's the problem.
I'm having trouble with textures, when i apply a texture on a plane or circle or anything it only textures in strips.
See attached photo.
See attached photo.
- im1205314850.png (789.44 KiB) Viewed 11031 times
...Or at least i thought it was fixed, but it really isn't.
As the render cleared i realized that now the texture is fine, it's just the bump map that is tiling wierd.
here is a render, it's at 147 samples, so it's not too clear, but it should do.
- im1205388378.png (713.83 KiB) Viewed 10888 times
Hi Photoguy,
I ran into the same problem and probably the answer to your problem is in this thread:
http://www.indigorenderer.com/joomla/fo ... em&start=0
Kram1032 made it very clear.
Hope it helped.
Hope it helped.
