Cicero
Cicero
Hi guys.
I felt like some high-brow stuff after grappling with my pin-up. Here's a ZBrush sculpt, very losely modeled from an actual (and far more majestic) Cicero bust. I re-used a slightly modified base mesh I did earlier to start this up. The rest was just a lot of sculpting, and a little texturing. The mat is a blend of phong and SSS. Lighting a basic studio setup.
The new, improved Blendigo digested the whole 700,000 poly mesh without chocking, and Indigo 1.0.7 (64bits) rendered it like a charm.
Tiny bit of Pshoping for colour and contrast and smoothing out one or two rough edges (the original model was 3m polys so it lost a bit of smothness in the transition but nothing dramatic).
- Cicero.jpg (234.3 KiB) Viewed 13325 times
- Kosmokrator
Cheers JaMon, Kosmo.
Roger
Thanks Roger. This one didn't take too long despite the SSS. Probably because it's such a basic studio setting. It was about 8 hours on a Quad at 2400x1800 pixels. And it was pretty clean when I stopped it.
Labello
I hear you. Ivy would be nice. It would boost my polycount even more though... Mmmmh.
Roger
Labello
jurasek: Thanks man. Here's a crop of the original.
suvakas: Hey Suv. You're very charitable. This piece was just rated as "bad" on ZBrushcentral and I got a bit of a bashing there. Definitely some way to go before I can produce a good sculpt.
OnoSendai: Cheers Ono. I'll upload it now. I'm not too sure about the marble either.
Vanessa07: I did try a more reflective version earlier, but it felt too much like plastic. I guess it's hard to find the right balance of IOR, Exponent and SSS. Also, I got a little marble statue at home which is very diffuse (more than this one) and a lot more transparent. I imagine it depends on how old and rugged the marble is, or how much it was polished. But you're right, this one could do with more work.
- Crop.jpg (39.83 KiB) Viewed 13172 times
Really? Very strange.BbB wrote: suvakas: Hey Suv. You're very charitable. This piece was just rated as "bad" on ZBrushcentral and I got a bit of a bashing there. Definitely some way to go before I can produce a good sculpt.
This looks very much like a master piece for an average Joe like me.
What kind of artistic background do you have (if i may ask)? Have you learned sculpting/painting or something like that?
They have very high standards there
I'm not trained, but I used to do a lot of drawing and had a few minor stints as an illustrator back in the days. My work today has nothing to do with art so CG (like photography before) is a way for me to keep at it while avoiding the messiness and time-consuming side of traditional graphic art. (Though this Indigo addiction is getting quite time-consuming now.)
