hi ,
first , i want to thank u all guys for this wonderful render.
second , i'm searching information about the parameters of the ini. file
(what every one of them says).
third , is there any other way besides the sketchup plug and the ini file that can control the speed / bounce parameters ?
expert parameters ?
Here you'll find some explanations.
Indigo uses his own default, that were saved in the inifile.txt till version 1.0.6 of Indigo.
Since 1.0.7 the Inifile is saved as xml, and no more the home of the Indigo defaults (they are saved internally).
You can change the advanced settings for each scene by defining them through the skethup export, thats the most convenienced way.
Feel free to browse the wiki to find out more!
Since BigFan did some realy great work on the Blender/Blendigo wiki part, you'll find there a lot of Information, tips and hints generally related on Indigo, or at least knowledge easy to pull over to any other 3D app Exporter usage!
