I teach AutoCAD in high school and I wanted to show students how Indigo can be used for architectural visualization. So I put Indigo on my portable HDD at home, fixed path in Indigowrapper file. In school's lab we all have restricted accounts. So I ran indigo, it started, but when i opened .xml file to render, I got an error. Screenshot is attached.
Is it fixable? If so, how?
Thank you!
Indigo 1.0.6 doesn't run under limited account!
- screen shot of an error
- indigo_error.gif (48.64 KiB) Viewed 6023 times
This is all log.txt has:
SSE present.
SSE2 present.
SSE3 present.
Using base Indigo directory path 'Z:\indigo'.
Scene file path: 'F:\indigo\previews\IMPcustom.xml'
Using working directory path 'F:\indigo\previews'.
Loading Scene 'F:\indigo\previews\IMPcustom.xml'...
At home Indigo runs fine. Same scenes, same everything. The only difference is that at home I am under admin and here, at work, I am limited account with all kind of restrictions.
SSE present.
SSE2 present.
SSE3 present.
Heya motorsep, please try something. Use a limited account at home
and check if it's the same issue. If not, then it is not the limited account
but a problem with something else. If it works at home, we can investigate
a bit more in another direction. First you have to make sure that the limited
account is the problem for sure. ;o))
take care
psor
take care
psor
"The sleeper must awaken"
Users browsing this forum: No registered users and 65 guests
