jViolet 0.4 alpha Release
dougal2
Post by dougal2 » Sun Feb 10, 2008 6:51 am
THIS IS A BUGGY ALPHA RELEASE - USE AND TEST AT YOUR OWN RISK
I would appreciate a few peoples comments on whether this works on your system, what you find wrong with it and any feature requests. :)
To run, extract the .zip somewhere and use the jViolet.jar file accordingly.
jViolet-0.4alpha.zip
(396.98 KiB) Downloaded 829 times
Pinko5
Post by Pinko5 » Sun Feb 10, 2008 6:55 am
Tnx Dougal2......I try it asap
Luca.
dougal2
Post by dougal2 » Sun Feb 10, 2008 6:57 am
Cheers.
BTW, this release has the multithreading capabilities disabled, so expect it to be slower than the original.
I'm working on making all the processing parts multithread compatible - at which point i'll enable the multithreading. But this isn't a simple problem to solve, so it might be a while before that happens.
psor
Post by psor » Sun Feb 10, 2008 7:51 am
Thanx Doug! I recommend to include some information about java's
memory handling. Under Windows the default -Xmx settings are
to low to load a bigger IGI. So under Windows you should use a
line like this ...
java -server -Xmx1024m -jar jViolet.jar %*
the "-server" switch will make the code a bit faster but under Windows
and especially if you use the JRE and not the JDK you have to copy
the folder called "client" from ...
..\java\bin\client
to ...
..\java\bin\server
Also a CMD file like this can help a lot ...
@set javadir="YOURJAVAINSTALLDIR\Java\jre1.7.0"
@set mem=1024M
@%javadir%\bin\java -Xmx%mem% -server -jar jViolet.jar %*
@if %errorlevel% neq 0 pause
Thanx for listening. :D ;)
take care
psor
"The sleeper must awaken"
dougal2
Post by dougal2 » Sun Feb 10, 2008 8:50 am
Oh yeah, thanks psor - i forgot about the Xmx thing. I usually have it set automatically by netbeans :roll:
In future I'll package the following batch file
jViolet.bat:
@set javadir="C:\Program Files\Java\jre1.5.0_14"
@set mem=1024M
@%javadir%\bin\java -Xmx%mem% -Xms%mem% -jar jViolet.jar %*
@if %errorlevel% neq 0 (
	@echo The path to Java in this batch file is probably wrong. Please edit this file.
	@pause
Wedge
Post by Wedge » Sun Feb 10, 2008 11:10 am
Hi Dougal, I just wanted to tell you what you may already know, that is, I do not think non-members can download/see attachments in this forum. :)
dougal2
Post by dougal2 » Sun Feb 10, 2008 11:13 am
That's OK wedge, because non-members will also not be able to me if it worked or not ;)
Wedge
Post by Wedge » Sun Feb 10, 2008 11:18 am
Non-members could become new members and very informing bug testers. :) Must keep an open mind...
eman7613
Post by eman7613 » Sun Feb 10, 2008 5:21 pm
for those who are bandwith concious, a smaller packaging.
to unpack run from comandline
unpack200 jViolet.pack.gz jViolet.jar
also, mines a single jar, not lib folder (hate that thing)
jVilot.pack.gz
(166.25 KiB) Downloaded 631 times
Yes i know, my spelling sucks
Big Fan
Post by Big Fan » Sun Feb 10, 2008 6:57 pm
new members should be discouraged because already 1617 people have had their lives taken away by indigo :wink:
alexmeyer
Post by alexmeyer » Mon Feb 11, 2008 4:49 am
Big Fan wrote:new members should be discouraged because already 1617 people have had their lives taken away by indigo :wink:
roflol, indeed. :lol:
dougal2
Post by dougal2 » Mon Feb 11, 2008 4:56 am
So, getting back On Topic. Can I assume the 23 people who've tried this have nothing to say because it worked?
alexmeyer
Post by alexmeyer » Mon Feb 11, 2008 4:58 am
Actually, I was just replying right now...
Maybe I'm just being clueless, but when I open an IGI file, it does nothing. No errors, but no displaying of the file either. From the "Show Output", it looks like it loaded the file just fine...
It *is* supposed to show something, correct? :P
psor
Post by psor » Mon Feb 11, 2008 5:34 am
@alexmeyer
Have a look at my first post in this thread ... :D ;)
take care
psor
eman7613
Post by eman7613 » Mon Feb 11, 2008 11:32 am
Okay, this could be b/c im running the regular version of viloet from wine, but whatev
There are two things i notice, and that is the inital tone & shade of the image is diffrent depending on the version (Violet & jViolet), and the chomatic aberation is diffrent. The right version is jViolet, left is Violet
Chromatic Aberration.png (812.95 KiB) Viewed 38612 times
