Putput DPI question
12 posts • Page 1 of 1
crojack
Putput DPI question
Post by crojack » Tue Feb 05, 2008 5:44 am
So, I noticed that when I bring in an image to PS, either the png that Indigo saves or one out of Violet, that it comes into PS at 72dpi. I know that that is the only size sketchup will output an image at, is that why the Indigo image is 72dpi? Doesn't seem like it should be limited to 72dpi. I ask because a lot of the stuff I render needs to be printed and having a higher dpi would be nice, even 150. I know that rendering huge and reducing the image size does a similar thing, but doesn't it take longer to render a much larger image?
dougal2
Post by dougal2 » Tue Feb 05, 2008 5:51 am
Well, it depends on the size you want to print or display.
if you want a 24"x12" print at 150dpi, you must render at 3600x1800.
There's no way around it. If you want large prints at high dpi, the render size goes way up.
crojack
Post by crojack » Tue Feb 05, 2008 5:59 am
So indigo can't output at a higher dpi? That doesn't seem correct.
(sorry for misspellings, my typing skills are horrible) :oops:
Post by Kram1032 » Tue Feb 05, 2008 6:02 am
You actually can pretty much ignore the dpi, as long as you watch your image on screen. Screens more or less have a resolution of 72dpi ;)
If you want to print it, you can have far higher resolutions. That's why you need the dpi.
crojack
Post by crojack » Tue Feb 05, 2008 6:09 am
I understand the screen dpi of 72 and that it is possible to change image size/dpi inside photoshop, but you can't add information to an image. Sure you can resize it and add dpi, but it will always come out blurrier when doing this.
That is why it is good to take digital photos really large than scale them down.
I was hoping, since Indigo uses camera settings, to be able to set a much higher resolution without having to render at such a huge size. It seems that it would help render times.
Post by Kram1032 » Tue Feb 05, 2008 6:12 am
Uhm...
Sorry, that doesn't work...
On the other hand, that's kinda what Supersampling does ;)
crojack
Post by crojack » Tue Feb 05, 2008 6:25 am
I'm more than likely being dense, but what doesn't work?
and, I don't think that there is a Supersampling option in Skindigo.
and I don't really know what supersampling is, but I will search!
psor
Post by psor » Tue Feb 05, 2008 6:47 am
I gotta jump in here ... 8)
I often hear people getting confused by DPI (dots per inch). And I really
recommend reading articles/tuts like this ... ;)
Understanding DPI and Image Resizing
Understanding Resolution
And in general, forget about DPI if you are rendering. If you need to
print something and the guy says "I need it in 300dpi" then you should
know what it means to your resolution that you'll choose for your output.
So please don't get overall confused by DPI and resolution ... :D :D ;)
Hope this will be of help! ;o))
take care
psor
"The sleeper must awaken"
FakeShamus
Post by FakeShamus » Tue Feb 05, 2008 6:48 am
yeah...the only thing that really controls the "size" of your digital image is the total pixel dimensions. dpi is just a ratio - 25 x 50 inches @ 72 dpi is the same as 9 x 18 inches @ 200 dpi.
so if you want larger size (in inches) at higher resolution (150-200 dpi) you need to render more total pixels. and yes, this will take longer than smaller total pixels.
Post by Whaat » Tue Feb 05, 2008 6:48 am
You have to configure supersampling using 'inifile.txt' with SkIndigo.
psor
Post by psor » Tue Feb 05, 2008 6:56 am
Supersampling has nothing to do with the topic guys. It is there to prevent
aliasing artifacts and furthermore to reduce noise a bit through the resizing
and the filtering used by the resizing itself. So please, please, double please
dot not mix those things up. :twisted: :cry: :wink:
nb: Supersampling is a factor e.g. Supersampling = 3
3 x resolution -> 3 x 800x600 = internal resolution of 2400x1800 -> resized to 800x600
No DPI involved ... because there is no printer in Indigo yet! :roll: :wink:
take care
psor
crojack
Post by crojack » Tue Feb 05, 2008 7:12 am
psor wrote:I gotta jump in here ... 8)
take care
psor
thanks psor!!
all is becoming clearer.
Whaat-
is supersampling enabled by default in Skindigo?
Users browsing this forum: Ahrefs [Bot] and 17 guests
