Hy guys,
I'm working since a few days with Indigo in addition to cinema 4d 10. I#Ve made a sample scene with 3 prawns, each one with an own material. One prawn gots a glass material and there is the problem...
After a few minutes rendering the result looks like below.
What am I doing wrong? I've used the search function and found some test scenes trying to find out how I can handle this, but the scenes are for older versions of indigo and the information of the tags in cinema gets lost...
Thanks for your help.
Cheers,
Chris
Problems with transparency
Azrael Crusader
- im1201428252.png (373.66 KiB) Viewed 3960 times
Azrael Crusader
no problem
Just be careful that you don't change those normals, that already are correct^^
Glass gets rendered black, due to three reasons:
- Normalsmoothing problems (affects all materials and is only around edges)
- Inverted Normals (doesn't affect diffuse, diffuse transmitter or phong)
- Mesh without thickness and with IoR 1 (affects all transparent materials with IoR)
Azrael Crusader
High Gain value is a problem tooKram1032 wrote:no problem
