[Req] Spherical HDRI support
14 posts • Page 1 of 1
Lord of the Rings Junkie
Post by Lord of the Rings Junkie » Tue Jan 22, 2008 2:02 pm
It would be nice if you could fix Indigo so that it works with spherical HDRIs, sometimes it's a pain to have to convert all of them to lat/long format.
Dacksoldier
Post by Dacksoldier » Tue Jan 22, 2008 5:19 pm
i've used spherical HDRI using .float file
Vanessa07
Post by Vanessa07 » Tue Jan 22, 2008 10:22 pm
Dacksoldier
How do you convert .hdr to . float file?
Dacksoldier
Post by Dacksoldier » Thu Jan 24, 2008 2:52 am
so i open the hdr in photoshop and just save it with .float on the end
thats what i did
ViennaLinux
Post by ViennaLinux » Thu Jan 24, 2008 9:23 am
Dacksoldier wrote:so i open the hdr in photoshop and just save it with .float on the end
thats what i did
.float?!
That will render correct? Dont think so.
drBouvierLeduc
Post by drBouvierLeduc » Thu Jan 24, 2008 9:56 am
Or use hdrshop : panoramic transformations -> latlong to spherical
ViennaLinux
Post by ViennaLinux » Thu Jan 24, 2008 10:44 am
drBouvierLeduc wrote:Or use hdrshop : panoramic transformations -> latlong to spherical
You mean the other way round?
I only have spherical hdrs.
Whats the best way for me?
- convert them to lat long and save them as exr?
Post by Lord of the Rings Junkie » Thu Jan 24, 2008 10:45 am
Changing a lat/long probe to spherical won't make Indigo use the spherical mapping. :wink:
@Vienna: Yes, right now you have to convert spherical to lat/long in HDRshop and convert to EXR.
Post by BbB » Thu Jan 24, 2008 9:41 pm
spherical .float files seem to work for me.
ViennaLinux
Post by ViennaLinux » Fri Jan 25, 2008 12:26 am
set the camera angle to 180 degress and render a shot of the sky hemisphere - then you know if it is mapped the right way.
Post by BbB » Fri Jan 25, 2008 1:09 am
I did a first test with a chrome ball. It is mapped the right way :D
Post by Kram1032 » Fri Jan 25, 2008 4:46 am
I guess, latLong is better than spherical...
Though, the less distortion due to changing the map mode, the better as the quality will decrease with each conversion...
Post by BbB » Fri Jan 25, 2008 4:58 am
I say we ought to use each map the way god intended them to be used...
psor
Post by psor » Fri Jan 25, 2008 8:19 am
"I say we ought to use each map the way god intended them to be used... "
Image Image Image
"The sleeper must awaken"
