AIR: AnotherIndigoResumer V1.1
7 posts • Page 1 of 1
SimonLarsen
Post by SimonLarsen » Sat Jan 19, 2008 11:24 pm
(Pretty clever name huh? ^^)
Hi, just like 80% of the other members in here, I've decided learn some programming. In this case it was Pascal (almost the same as Delphi), since I've already tried C++ and thought it was clumsy not suitet for a newbie.
AIR is my second real program ever (first one was a Notepad-replicate), and I doubt it's better than Daniel Nieto's, but I thought I would post it anyway.
Installation: Just unzip it, and open the exe. ^^ (Older Indigo versions will complain about missing inifile.txt, if so, you will have to place it in you Indigo-folder.)
Well, tell me what you think, and what it is missing! :D
UPDATE: Below normal works now. But, unfortunately it has to create a bat-file.
UPDATE: V1.1 Just a small update. You can now choose between 'Resume, render and edit'.
Resume and render is pretty selfexplanatory.
Edit just open the selected igs in Notepad (select igs before selecting edit.)
Made it delete the bat when it was closed, but it had some problems so i removed it again.
Coding is fun. ^^
AnotherIndigoResumer 1.1.zip
(443.79 KiB) Downloaded 390 times
afecelis
Post by afecelis » Mon Jan 21, 2008 8:02 am
wow! interesting little app! And it's the only one (of the 3 resumers available) that has done the job fine resuming renders under linux via wine!
Thanks a lot! great work! :D
SimonLarsen
Post by SimonLarsen » Thu Jan 24, 2008 5:15 am
afecelis wrote:And it's the only one (of the 3 resumers available) that has done the job fine resuming renders under linux via wine!
Great, that was pretty much what I was hoping for.
Thanks. :D
zamolet
Post by zamolet » Tue Jul 01, 2008 10:23 am
Really cool and effort-saving little app :D
Post by Borgleader » Tue Jul 01, 2008 10:25 am
Nice :) Thanks a lot!
Juju
Post by Juju » Thu Jul 03, 2008 3:04 am
Borgleader wrote:Nice :) Thanks a lot!
I second that.
ronald8
Post by ronald8 » Fri Jul 04, 2008 9:19 am
afecelis wrote:... that has done the job fine resuming renders under linux via wine!
I second that! Works fine with wine 1.0 and ubuntu 8.04
Thank you!
Users browsing this forum: No registered users and 119 guests
