SkIndigo 1.0.4
SkIndigo 1.0.4
Post by Whaat » Tue Dec 18, 2007 6:36 am
Use this version with Indigo 1.0.4.
You must download the new previews folder (SUpreviews) or change the name of your existing previews folder to 'SUpreviews' for this new version to work. As always, make sure this folder is in your Indigo directory (version 1.0.4)
INSTALLATION
1. Copy SkIndigo.rb into your SketchUp/Plugins directory
2. Copy the SkIndigo folder into your SketchUp/Plugins directory
3. Copy the SUpreviews folder into your Indigo directory
4. Remove any previous versions of SkIndigo from your SketchUp/Plugins directory
#Version 1.0.4
#Added: support for IES profiles
#Changed: changed previews folder name to SUpreviews to avoid conflicts with other exporters' preview scenes
#Added: aperture diffraction support
#Changed: made IGM import backwards compatible with older versions of Indigo (not fully tested)
#Added: Water preset (credit CoolColJ)
Aperture diffraction is currently enabled by default in order to facilitate testing. It will be disabled by default in the future.
I have re-written about 90% of the code since the last release so it is very likely that some features will be broken. I have not had the time to fully test this one. Please let me know of any bugs. Thanks!
UPDATED 19 Dec 07: Fixed 'Cancel Changes' button in Render Settings dialog
SUpreviews.zip
Previews folder (required download)
(3.31 MiB) Downloaded 761 times
SkIndigo.zip
fixed Render Settings Cancel button
(1.44 MiB) Downloaded 1231 times
cpfresh
Post by cpfresh » Tue Dec 18, 2007 8:16 am
thank you Whaat! i look forward to testing this baby out! :D
Stinkie
Post by Stinkie » Tue Dec 18, 2007 8:30 am
Thanks, Whaat!
crojack
Post by crojack » Wed Dec 19, 2007 9:19 am
Thanks Whaat! Just installed and found a couple issues.
When I hit "Cancel" in the Render Settings, I get a Runtime Error and it asks me if I want to debug. I said ok, and it took me to a Microsoft Editor to the Html line for the Cancel button.
Says in the Error box-
Line: 403
Error: Object Expected
Also, not really a bug I think, but when I open the Render Settings dialog box, if I don't make any changes and start hitting "Undo" it undo's what I did in the model, like hitting Ctrl-Z.
Anyways,
Looks great, hopefully I'll get some time soon to do some more renders to post.
ribo
Post by ribo » Wed Dec 19, 2007 9:24 am
Thanks Whaat.
Post by Whaat » Thu Dec 20, 2007 6:30 am
crojack wrote:When I hit "Cancel" in the Render Settings, I get a Runtime Error and it asks me if I want to debug. I said ok, and it took me to a Microsoft Editor to the Html line for the Cancel button.
Line: 403
It should be fixed now. Thanks.
It's not really a bug - more of a side-effect :wink: . It would be a real pain to 'fix' this. If it's causing people grief, I can just delete the 'undo' button.
Post by Pibuz » Sat Dec 22, 2007 12:19 am
Hi Whaat!
Just trying v1.0.4, and i get the error message i attach.
I tried to put a simple sketchup material and to get a preview, but the message pops up starting the render (even for the preview only).
What can it be?
Post by Whaat » Sat Dec 22, 2007 2:39 am
pibuz,
check your SUpreviews folder. Is there a 'textures' folder and does it contain the concrete block texture?
Post by Pibuz » Sat Dec 22, 2007 2:41 am
Yes!
The first thing i checked..
crojack
Post by crojack » Sat Dec 22, 2007 5:21 am
Whaat wrote: It's not really a bug - more of a side-effect :wink: . It would be a real pain to 'fix' this. If it's causing people grief, I can just delete the 'undo' button.
Yeah, I didn't think that it was a bug, just king of interesting like you said.
Post by Whaat » Tue Jan 01, 2008 7:37 am
Pibuz,
Have you figured out this problem, yet? Does it only happen with material previews? Try deleting the file 'indigo1_0_4_path.txt' and try deleting and re-installing SkIndigo. I am kind of stumped about this one.
Post by Pibuz » Wed Jan 02, 2008 7:45 am
Bof, i just went back to 1.0.1, no problem Whaat! :D
But i'm going to try your tip, surely!
I'll be able to tell you tomorrow, i think! Thanks!
lorom
Post by lorom » Thu Jan 03, 2008 12:22 pm
I have the same problem and I tried what you said Whaat. But if I delete 'indigo1_0_4_path.txt, then when I start Sketchup the software ask me where is the indigo.exe I choose the right directory and the 'indigo1_0_4_path.txt come back in the same place.
Post by Whaat » Thu Jan 03, 2008 4:26 pm
Pibuz/lorom,
I really need more information in order to fix this.
- does it only happen with material previews?
- does it happen with ALL preview models? (sphere, cube, etc.)
- does it ALWAYS happen every time you preview a material with a texture?
- does it ONLY happen with SkIndigo 1.0.4?
If you can find a case where it happens, please post the 'previewmats.igs' file that you will find in your 'SUpreviews' directory.
Thank you
Post by Pibuz » Thu Jan 03, 2008 9:34 pm
Hi Whaat!
So:
- the problem comes out with material preview AND image render
- it comes out with all metrial previews
- it happens every single time i launch a whichever rendering
- ..but it only happens with SkIndigo 1.0.4 (luckily)
BTW, SkIndigo is however GREAT!
