I'm reading that MLT based renderers have issue with caustics behind dielectrics. What's the deal with that?? Can Indigo do those??
Thanks,
Slobodan
caustics behind dielectric??
yes it can, since some time, now.
There already was a HUGE test-thread, which showed the problem and went on, when the problem was solved and much more recently, there was a test, again
You just need to make sure, that your Max_num_consec_rejections (a render-setting, found in the inifile and in theory also in your exporter's gui) is at at least 1000 - then, you should see caustics through transparent stuff
