hello
i'm in blender 2.45 (linux fedora) and indigo 0.9 with blendigo. I try to use texture but they don' t appears in my render scene, where must i put them ? in which directory ?
thks
texture problem
They must be at the same level relative to both programs. I find it easiest to to have blender, indigo, and my textures folder all at exactly the same level so relative paths will always work. For example:
/home/wytraven/blender
/home/wytraven/indigo
/home/wytraven/textures
as opposed to say:
/home/coolprograms/indigo
/shared/textures
alternatively edit the exported .igs in a text editor and fix the paths
as opposed to say:
/shared/textures
Re: texture problem
It seems you haven't assigned your textures in blender for blendigo export.freaks wrote:hello
thks
If you would applied them correctly, Indigo would crash with an error message about Texture map not found, and NOT render the scene without them...
ahhh ok freaks you need to configure your materials in blendigo using the "materials" button. forget about using blender material editor. just assign a material in blender then use blendigo to actually define it. Albedo map = base color texture, Bump map = bump texture, and Exponent map = specular texture.
