Inacurate Cut Crystal Test
WytRaven
Post by WytRaven » Sun Oct 14, 2007 2:38 am
It looks pretty but it's not accurate at all. 'Crystal' material uses IoR 2 with a cauchy B inaccurately calculated from from heacy flint data (base IoR ~1.75) so it's miles off acurate.
Render time 200h 20m before I pulled the plug.
manitwo
Post by manitwo » Sun Oct 14, 2007 2:56 am
thats what i call clean! :shock:
Post by BbB » Sun Oct 14, 2007 3:43 am
Nice, fine caustics. But can you let it cook a bit longer to eliminate the noise in the glass?
WytRaven
Post by WytRaven » Sun Oct 14, 2007 7:03 am
No BbB ;) I promise I'll let the next cut crystal test render till there's not an iota of noise remaining. Hello from Linux by the way. Finally got Ubuntu installed...destroyed my Vista installation in the process :shock:
zsouthboy
Post by zsouthboy » Sun Oct 14, 2007 7:40 am
I doubt you actually destroyed your Vista install, unless you completely repartitioned your drive.
If you need help, start an OT thread :)
WytRaven
Post by WytRaven » Sun Oct 14, 2007 7:56 am
Oh I destroyed it alright...well Ubuntu destroyed it. Totally stuffed up my partition table on first install attempt. Wouldn't boot Ubuntu from Grub, wouldn't boot Vista from Grub "Unable to mount partition" error for both.
It's all good I have it going now and I have used Ubuntu to backup the other partitions on the screwed drive. Moved them to my secondary drive. Will now completely repartition primary drive and reinstall Vista there.
Post by Kram1032 » Sun Oct 14, 2007 8:05 am
:shock:
The inaccuracy doesn't matter! It's great as-is :D
Stur
Post by Stur » Sun Oct 14, 2007 10:11 am
Inaccurate ?
For a high end mesuring device maybe, but very accurate for human oeil ;)
Very clean render !
Post by BbB » Sun Oct 14, 2007 10:27 am
Ha! I was kidding master. :D
I just can't see any noise left. 200h! How could there be?
CoolColJ
Post by CoolColJ » Sun Oct 14, 2007 11:50 am
render is too big!
very nice, when scaled down for my monitor :)
WytRaven
Post by WytRaven » Sun Oct 14, 2007 3:32 pm
Lol Cool, that's the res of my monitor 1920x1200 :)
Kosmokrator
Post by Kosmokrator » Sun Oct 14, 2007 8:37 pm
looks so nice the dispersion inside the glass....but 200h is too much!!
great test WytRaven.....keep it up!
Post by Kram1032 » Sun Oct 14, 2007 9:49 pm
you know what?
Now, I want a hi-res prism :P xD
Kmarius
Post by Kmarius » Tue Oct 16, 2007 2:15 am
Good work!!
CoolColJ
Post by CoolColJ » Tue Oct 16, 2007 6:10 pm
WytRaven
what sample count did you reach per pixel?
